Thread: 2005 Passat TDI PD 130 bhp Timing Belt Change
Results 1 to 10 of 17
  1. Question 2005 Passat TDI PD 130 bhp Timing Belt Change
    Apr 2009
    Wiltshire, United Kingdom
    I am hoping that someone can assist me.....
    I am getting conflicting information on the frequency for changing the cam / timing belt on my VW. I have a 2005 VW Passat Highline Estate TDI PD 130 bhp. My local dealer tells me that the recommended interval is 4 years or 60,000 miles. But the service schedule in the car documentation gives 80,000 miles as the interval for changing the belt, with no time interval. Several threads on this forum seem to be saying other times / mileage intervals.
    Also, on this forum, some members are recommending that other items such as belt tensioners and the water pump should be changed at the same time as the timing belt.
    I would be grateful for advice on all the above to ensure that I avoid the catastrophe of a belt failure and minimise costs.
    Many thanks.
    The vehicle engine number is AWX 10570. The vehicle was first registered in April 2005 and has 52k miles on the clock.
  2. Re: 2005 Passat TDI PD 130 bhp Timing Belt Change
    Norfolk
    You get conflicting information because at times vw can't make up their mind. Your handbook probably says 80k or 5 years. The replacement kit is for belt, tensioner and idler. It's a good idea to change the pump at the same time. If you don't and the pump fails, the whole lot has to come off again, so basically it's unwise not to change the pump. If you ring round dealers you should be able to find a decent price.
  3. Re: 2005 Passat TDI PD 130 bhp Timing Belt Change
    Oct 2006
    Sunny slightly hilly Norfolk
    VW are now specifying 4 years or 60K on all cambelts. Not worth the risk to go longer really. Like someone said, ring round for prices as they vary wildly!
    2016 VW Tiguan Match Edition (Nimbus Grey) , 09 Ibiza 1.4 SE SC (Nayara Blue), 2014 Leon 1.2 SE (Candy White).
  4. Re: 2005 Passat TDI PD 130 bhp Timing Belt Change
    Apr 2009
    Great information. Many thanks, guys. I will start getting some pricing (I already have an estimate of £350 approx. for replacing just the cam belt (which I will check includes the kit mentioned by martin1810 above)) from Martins, my local VW dealer here in Hampshire.
  5. Re: 2005 Passat TDI PD 130 bhp Timing Belt Change
    Jul 2008
    Beverley, East Yorkshire
    Quote Originally Posted by knoxman View Post
    Hi
    I had mine done at the local SKODA dealer (same car as yours albeit an older model) - they were the cheapest (even cheaper than the local VW main dealer and the specialist independants). My orginal quote was £400 and included the belt, tensioners, water pump and 2 new drive belts. However, on strip down the alternator tensioner was found to be worn out - this put the total cost up to £503! Very pleased with the service which inlcuded a courtesy car for two days - but members are right - the prices vary widely! My car had had the first cambelt change at 60,000 (VW main dealer), and not wanting to fit a new engine decided to change mine at 115,000.
  6. Re: 2005 Passat TDI PD 130 bhp Timing Belt Change
    Jul 2008
    Just done mine myself. Full belt kit + tensioners + water pump + G12 coolant + oil and filter-service change £144. GSF with taxi discount.
    Easy to do but easier with 2 people to help lift the front off/round. No need to lock anything as long as you're careful not to move the cam/crank etc... Whole job took 3 1/2 hours. I done mine every 60'000 with oil/filter every 6000. HTH.
  7. Re: 2005 Passat TDI PD 130 bhp Timing Belt Change
    Feb 2009
    same as above, pretty easy job around 3 to 4 hours, well worth a go yourself hardest bit is removing front of car, once this is pulled around to side the belt and tensioner is replaced in around 1/2 hour or so, it cost me £76 (belt and tensioner)and 3hrs last sunday, well cheaper than the ********....
  8. Re: 2005 Passat TDI PD 130 bhp Timing Belt Change
    Jan 2009
    Stoke-on-Trent
    You would be best finding a good local vw or audi specialist to replace the cambelt and waterpump, you would save loads compared to the dealers!
    Servicing, Repairs, Diagnostics and Re-mapping in Staffordshire
  9. Re: 2005 Passat TDI PD 130 bhp Timing Belt Change
    ChillOut Guest
    I have the same car and same dilema. My local specialist will charge £350 all in with pump and aux belts and VAT (using ALL VAG parts, he won't fit anything else). Main dealer was around £550 for the same job.
    I am toying with the prospect of pushing my luck and selling the car when its five year old at just under 80,000. But if you have any plans to keep it long term, you may as well do it ASAP.
    In the end its a gamble - £350 pience of mind or £3K for a new engine (or more). And most buyers will ask the question and knock you down on the price. Flip side is the car is only worth around £5K!
    But if you do go for it, do change the pump and belts at the same time - most of the cost is the labour.
  10. Re: 2005 Passat TDI PD 130 bhp Timing Belt Change
    Jul 2008
    I have the same problem, but my passat is an 04 highline. I called the dealer it was last serviced at, and they said the 04 model onwards PD models only needed cambelt changes at 80k or 5 years.
    I normally only service my vehicle based on the milage interval, and NOT the yearly/time basis. Just confused as to what to do regarding the cambelt as it is 5 years old but has only done 59k thus far. If i do the service fairly soon, do you think it is wise to buy the parts from the local skoda dealer? This will include the cambelt kit, the water pump (now with metal impeller?), the fuel, oil, air and pollen filters. It is after all the same engine in almost the same model that they sell (superb).
    Another question relates to the variable service interval. The handbook says its on longlife, the last service it had was at 46k, so it has now done over 13k and the service light has not come on. Do you think i should just wait until the light comes on, and change over to the fixed interval servicing? Very confusing!!
  1. Cost of Major service & Timing belt change
    By Loofer in forum Chat - Anything with wheels
    Last Post: 08-10-2011, 01:56 PM
  2. passat 1.9 tdi sport timing belt ??
    By tennentsfan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-05-2008, 01:01 PM
  3. 100 bhp timing belt service intervals
    By spiritse in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-09-2007, 12:41 PM
  4. Golf TDI 150 timing belt change
    By GKMVW in forum Golf MK4 - 1999 - 2004
    Last Post: 22-03-2007, 11:10 PM
  5. Transporter 2.5 TDI - Timing Belt diagram
    By SMC in forum The Commercial Range
    Last Post: 20-09-2006, 11:42 AM
