Thread: Steering column switch trim torx screw size?
  1. Steering column switch trim torx screw size?
    Sep 2008
    mostly in the garage
    Hi Folks,
    Well I've finally got hold of the parts to retro fit cruise control and went to do it this afternoon. I was stumped straight away as I only have torx sockets which wont fit up into the lower cowl. It seems I need a long reach torx screwdriver so can some knowledgeable soul please tell me what size the two torx screws are so I can go buy one? Oh and are they normal torx or the security type with the pin in the middle?
    Cheers, Chaser...
  2. Re: Steering column switch trim torx screw size?
    Torx screwdriver T8
  3. Re: Steering column switch trim torx screw size?
    Sep 2008
    Thanks Kenney, I'll get one and try again tomorrow!
  4. Re: Steering column switch trim torx screw size?
    Sep 2008
    can't seem to find one! ********* have one but it's too short........anyone know a main stream supplier where I could get one without resorting to an internet buy??
  5. Re: Steering column switch trim torx screw size?
    Try with an ordinary thin screw driver,you might be lucky,and get them loose
  6. Re: Steering column switch trim torx screw size?
    Sep 2008
    Already tried that one, T8 is soooooo small though, can't get anything in. It's just a bit frustrating, I'll get the ********* one if I have to and cut the handle back a bit.
    Thanks again..
  1. Replies: 21
    Last Post: 16-07-2015, 03:07 PM
  2. "How To" remove boot trim panels on an A3
    By djgilson in forum Audi
    Last Post: 09-04-2014, 01:18 PM
  3. Had cruise control fitted today.
    By paulr130pd in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2010, 09:42 PM
  4. Tune Weber carb (not type specific)
    By bishbosh66 in forum Volkswagen
    Last Post: 30-01-2008, 11:34 AM
  5. mot
    By graham toogood in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-10-2007, 06:20 PM
