Thread: Power Loss / Turbo loss on VW Passat 1.9TDI
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 50
  1. Re: Power Loss / Turbo loss on VW Passat 1.9TDI
    #21
    Apr 2009
    All,
    I truely appreciate the fact that you guys are helping me out on this. I have now eventually found a mechanics guy in bolton who does a diagnostic check, car is due to go in tomorrow.
    Now there appears to be another problem! As soon as I switch the car on the orange coil light goes on and flashes and it says "engine Workshop" on the dash!
    Is this something serious? I am really worried now as I have the turbo problem and now this engine worksop thingy with the coil light flashing. I am worried this is going to cost some money now!
    Please can someone shed some light on this pls
    Regards
  2. Re: Power Loss / Turbo loss on VW Passat 1.9TDI
    #22
    Norfolk
    It's just telling you that it has logged fault codes that need reading. It doesn't mean they are serious, just that you should get them investigated.
  3. Re: Power Loss / Turbo loss on VW Passat 1.9TDI
    #23
    Norfolk
    Mubsy... Once you have a code read, You will get advice that is more relevant. Too much guessing is pointless as Crasher says. People often spend lots of money replacing parts to avoid paying for a code read. This is usually false economy.
  4. Re: Power Loss / Turbo loss on VW Passat 1.9TDI
    #24
    135 Post(s)
    2026 Post(s)
    Mubsy, I would not be surprised if all your problems were just due to a cheap and easy to replace brake light switch fault.
  5. Re: Power Loss / Turbo loss on VW Passat 1.9TDI
    #25
    Nov 2008
    how could a brake light switch cause this problem crasher ?
  6. Re: Power Loss / Turbo loss on VW Passat 1.9TDI
    #26
    Apr 2009
    The drivers side brake light was not working (I didn't realise) so bulb was replaced and the Coil light no longer flashing and the "engine Workshop" message no longer coming.
    The problem of turbo not kicking in still there, will go and do the diagnostic today and let you guys know what happens. Is there something specific the diagnostic chap needs to do whilst he doing the diagnostic check, as I have read somewhere that you get a rod and poke an area of the car whilst doing the diagnostic and it will solve some problem??
  7. Re: Power Loss / Turbo loss on VW Passat 1.9TDI
    #27
    135 Post(s)
    2026 Post(s)
    If you use the sites search facility you can read about 10,000 posts regarding brake light switches. The switch is a dual purpose unit. There are two contacts; one feeds the brake lights and the engine ECU and the other only the engine ECU as a double check. The system is known as Electronic Performance Control (EPC) and the brake light switch is part of the safety system and the code is likely to be “00741 Brake pedal monitoring Implausible signal” or “16955 Brake light switch F Implausible signal” and these will make the glow plug light flash and can cause the engine to lose power. Maybe the new bulb will have cured it, it can cause the same code. The part that is “poked” as you put it is the turbo vane actuator but this should only be encouraged to move whilst in Basic Settings 04, Main group 011 with the status in Block 2 showing “ON”.
  8. Re: Power Loss / Turbo loss on VW Passat 1.9TDI
    #28
    Apr 2009
    Hi Crasher,
    Just done a diagnostic on the car the following codes showed up:
    17965 - P1557 Turbo/super charger overboost, Condition: control limit exceeded
    16955 - P0571 Brake switch (a) Sporadic:Circuit Malfunction
    He didn't understand how to do the poking and he didn't understand how to change the diagnostic machine in different modes.
    I need to know pictorially what to do now as I plan on doing the work myself and am a complete novice with cars in order to save money! can you show me with pictures (as done in your previous post) what I need to do to solve my rpoblem.
    Help much appreciated.
    Regards
  9. Re: Power Loss / Turbo loss on VW Passat 1.9TDI
    #29
    135 Post(s)
    2026 Post(s)
    Do you have a registered copy of VAG-COM at your disposal?
  10. Re: Power Loss / Turbo loss on VW Passat 1.9TDI
    #30
    Apr 2009
    Nope - y?
  1. Loss of Power Passat 1.9 TDi 130 bHP 2001
    By tmirza in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-12-2013, 08:52 AM
  2. Passat Power Loss and Black Smoke
    By Buzzdarkmonth in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-01-2008, 08:59 PM
  3. Blown Turbo on AFN 1.9TDi engine?
    By justbretta in forum Archive posts
    Last Post: 18-12-2007, 04:56 PM
  4. Power loss, turbo??
    By bbb in forum Passat - Archive Topics
    Last Post: 28-06-2007, 05:07 AM
  5. Power Loss 1.8 Turbo Passat
    By ANGELO33 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-06-2007, 10:54 AM
