Thread: 03 plate 150 golf tdi, juddering , loss of power
Results 11 to 20 of 28
  1. Re: 03 plate 150 golf tdi, juddering , loss of power
    Sep 2008
    newtownards n.i
    try swaping someones turbo boost sensor first as this is often overlooked and was the prob. with mine
    2 0 0
  2. Thumbs up Re: 03 plate 150 golf tdi, juddering , loss of power
    Mar 2007
    U-96
    Hi Bohoo,
    Thanks for that constuctive post and for your thanks. Given Crasher's efforts and experience, I think that he also warrants thanks.
    Regards,
    TR7
  3. Re: 03 plate 150 golf tdi, juddering , loss of power
    Apr 2009
    car was fine this morning, put some additives in it [forte] last night took it it for a long spin[100 miles] . then as soon as the cr got up to normal temp, back to juddering shuddering and loss of power, my mates having a look at it tommorow i will keep you posted many thanks to 1 and all.
  4. Re: 03 plate 150 golf tdi, juddering , loss of power
    Apr 2009
    fault code16687?
  5. Re: 03 plate 150 golf tdi, juddering , loss of power
    135 Post(s)
    2036 Post(s)
    16687 (P0303) Cylinder 3 Misfire recognised.
    Change the in head harness, a very common fault and cheap and easy to do.
  6. Re: 03 plate 150 golf tdi, juddering , loss of power
    Apr 2009
    still no joy fellas. checked the wiring in the top end to the harness (to the injectors?) and no faults found, changed the cam shaft senser, my mate thinks its the injector or the lobes on the cam worn, gutted. dont know how we've come from the turbo intermittent problem to this, all codes were erased and the turbo intermitent hes not come back, but the problem is the same.
  7. Re: 03 plate 150 golf tdi, juddering , loss of power
    #17
    135 Post(s)
    2036 Post(s)
    If he checked the harness he would have been able to see if the injector lobes on the cam were worn. I suggest you change the in head harness.
  8. Re: 03 plate 150 golf tdi, juddering , loss of power
    #18
    Apr 2009
    if the test showed no faults on wiring in the harness, could there still be a fault with the harness? many thanks once again
  9. Re: 03 plate 150 golf tdi, juddering , loss of power
    #19
    135 Post(s)
    2036 Post(s)
    Yes I have seen that happen, change the harness and whilst in there, check the cam lobes.
  10. Re: 03 plate 150 golf tdi, juddering , loss of power
    #20
    Apr 2009
    my good friend took the car to bits this evening took the cam out, lobes are worn. this will be the end of the saga fingers crossed. about 200 ish for a new one?
  1. Intense TDI power - The Audi A3 TDI clubsport quattro
    Last Post: 18-05-2008, 10:12 AM
  2. Spec differences between golf 130 and 150?
    By The Bishmeister in forum Golf MK4 - 1999 - 2004
    Last Post: 12-03-2008, 12:41 PM
  3. TDI Sudden Power Loss! Later higher MPG?
    By TDI-3 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-03-2008, 05:32 PM
  4. 80 Tdi loss of power under load
    By frainj in forum 80 - 90
    Last Post: 15-08-2007, 08:31 PM
  5. golf 4 gt tdi power loss help, (PLEASE'S)
    By golf4TERRY in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-07-2007, 06:07 PM
