Thread: wheel wobble?
  1. wheel wobble?
    Feb 2009
    Middlesbrough
    when breaking in my golf (1999 stdi) i have noticed that the wheel vibrates abit is this normal? thanks tom
    with out dissapointment you cant appreciate victory
  2. Re: wheel wobble?
    135 Post(s)
    2042 Post(s)
    You have warped discs. When the discs are removed for replacement the hubs MUST be checked for run out on the surface outside of the bolt holes as distortion here (due to Muppets over tightening wheels) is very common and means a new hub and wheel bearing.
  3. Re: wheel wobble?
    Apr 2009
    borders
    this is probably because your discs will be warped mate.these will probably need replaced for new it may be due to over heating so make sure that your calipers are not siezed.
  4. Re: wheel wobble?
    Feb 2009
    Middlesbrough
    i dont really use the breaks that hard though and the discs look pretty new :/ have to wait for now cant afford it after the wishbone issue :P it isnt that bad jus feel it through the wheel when i break more so when i am near to a stop i would say
  1. Replies: 21
    Last Post: 16-07-2015, 03:07 PM
  2. Had cruise control fitted today.
    By paulr130pd in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2010, 09:42 PM
  3. changing Sline wheel.
    By Jop in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-03-2009, 09:36 PM
  4. How does the Quattro system work?
  5. Parrot CK3000 intstall with Multican OEM steering wheel control
    By Mikey_p in forum Audi A3 - Archive Topics
    Last Post: 03-06-2007, 05:35 PM
