Thread: Mpg Clock Reading Erratic
  1. Mpg Clock Reading Erratic
    Mar 2007
    I know the clocks have 3 settings for the average mpg 2 user settings and 1 what i belive to be an average
    the 2 user settings that are used for single journeys seem to work fine getting an average of 44 mpg
    but the other setting were the display doesnt show a 1 or 2
    what i believe to be an overall consumption is completely erratic
    the fuel consumption fluctuates from anything between -- and 199 mpg continuosly changing every few seconds to anywhere in between the numbers above
    is this normal ??
    tried reading it up in the owners manual but dont make sense
  2. Smile
    Nov 2006
    There should be three mpg indicators; one that adjusts immediately to how far the accelerator pedal is pressed' one that gives you an average for your current journey (option 1) and one for a longer average (option 2).
    Aug 2006
    Devon, UK
    Yep, it's normal.
    The instant MPG readout fluctuates depending on throttle and speed. 199 is the maximum, -- means infinite (the car is coasting and not using fuel), and the other readings are just what they are. This reading is not particularly useful apart from learning how to drive for the best MPG. When you pay attention to it, you will be amazed at how much difference a small change in throttle will make! Get to know your car and it will treat you well.
    Passat Sport Estate 2001 1.9 TDI PD
    100k miles
  1. Setting time clock?
    By Lythan guy in forum Polo - Derby - Lupo - Fox
    Last Post: 11-04-2007, 04:39 PM
  2. Reset Service Clock
    By name43 in forum Passat - Archive Topics
    Last Post: 10-03-2007, 10:45 AM
  3. New to Reading Berks
    By The Boss in forum New Member Introductions
    Last Post: 04-03-2007, 11:04 PM
  4. Passat clock trouble
    By cj1978 in forum Passat - Archive Topics
    Last Post: 04-02-2007, 06:39 PM
  5. C Reg Volkswagen Golf MK2 1.3 (3,220 genuine miles on clock)
    By beverage in forum Golf MK2 - 1984 - 1992
    Last Post: 21-12-2006, 11:02 AM
