Thread: interior lighting
  1. interior lighting
    Mar 2009
    IRELAND
    HELLO all,
    not a big prob but on my 2003 passat all the doors turn on the interior lights and under door lighting apart from the passanger door . no interior lights come on at all when you open door .. i have looked at wires and look good. is there a swicth in
    the door or some thing that could be fauty??
  2. Re: interior lighting
    Dec 2007
    you say you checked the wires! did you replace the bulb???
  3. Re: interior lighting
    May 2007
    Just Outside Glasgow, UK
    Quote Originally Posted by gortex View Post
    HELLO all,
    I believe the sensor is built into the door lock, when opened it activates the lights. I had issues with the lights and locking, replace the lock for that door and lights started working when that door was opened, may by the same in your case.
    Shaiboy_UK
  4. Re: interior lighting
    Mar 2009
    IRELAND
    that was it . put in new lock has done the trick.
