Thread: The Dreaded Rear Wiper/Wash!
Results 1 to 10 of 10
  1. The Dreaded Rear Wiper/Wash!
    Near Blackpool
    48 Post(s)
    Hi everyone. My rear wash has been doing some strange things... When i spray the water the jet of water does not stay straight it moves with the wiper. It used to be solid and didnt move. Then moved a little bit. Now just goes fully with the wiper strokes. Whilst having my turbo looked at i asked them to take a quick look at that. They said it would need a new moter as the pipe goes threw the moter and its that that is probably sticking and quoted me £70 for a new moter!. On my MK3 golf i could remove the whole pipe and replace it. Any one any ideas? Can you remove the whole pipe or does it really need a new moter ?
    Any replies greatly appreiciated!
  2. Re: The Dreaded Rear Wiper/Wash!
    Near Blackpool
    48 Post(s)
    I have sourced a repair kit : Part Number 8L0998711. The repairs the internal copper pipe that corodes . You may be lucky and be able to greese up the plastic feederpipe and brass but like most it will be broken or completely ceased. I shall return once i get the kit tomorrow and install it.
    Last edited by jonathanfenton; 02-04-2009 at 04:12 PM. Reason: Sarcasm Apparantly Not Allowed/Appreciated At VW Audi Forum
  3. Re: The Dreaded Rear Wiper/Wash!
    Oct 2005
    Thanks for all the replies? Are you serious, you gave it an hour and a half!
    Glad you found a solution though - report back when you've fitted and tested.
  4. Re: The Dreaded Rear Wiper/Wash!
    Near Blackpool
    48 Post(s)
    My appologies i am just getting fed up with it. Its one thing after another with it so i seems i am perminatly on this site looking for solutions to problems!
  5. Re: The Dreaded Rear Wiper/Wash!
    Feb 2009
    Middlesbrough
    snappp
    with out dissapointment you cant appreciate victory
  6. Re: The Dreaded Rear Wiper/Wash!
    Feb 2009
    Middlesbrough
    how much are the repair kits? thanks tom
  7. Re: The Dreaded Rear Wiper/Wash!
    seems a common problem,went to vw as someone told me there was a repair kit but they just tried to sell me the full motor.my copper pipe had rotted but there was still a little bit on both ends so just used a plastic pipe out the middle of a squeeze bottle .job done
  8. Re: The Dreaded Rear Wiper/Wash!
    Near Blackpool
    48 Post(s)
    Quote Originally Posted by tdigolf View Post
    £20 ish. I think the one i ordered was £23+vat. so £26.45. You could get a secondhand moter for that. But the pipe in that could be on its way out... If it goes again i think i will use pipeing like geord1egooner said. I will let you know when i get it tonight how i went on. The garage warned me it was a difficult job.
  9. Thumbs up Re: The Dreaded Rear Wiper/Wash!
    Near Blackpool
    48 Post(s)
    Well I got the kit. Was going to take pictures but my phone is broke!. You get a full reconditioning kit. You get new cogs and grease. A whole new spout and copper pipe. The instructions are easy to follow. It works a dream now! If you have the problem of the jet spinning and not staying straight then i would 100% recommend this kit!
  10. Re: The Dreaded Rear Wiper/Wash!
    Jan 2009
    Mine was starting to go the same way, so I managed to get the copper pipe out, without breaking it, cleaned it up with wet an dry, and regreased it with castrol LM grease, and job done. I figure spending 30 minutes once a year regreasing saves you money. I must add, that without a vice, you will struggle to get the copper tube out.
  1. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
  2. How does the Quattro system work?
  3. Option Codes
    By Samcat in forum Passat - Archive Topics
    Last Post: 23-11-2006, 11:25 AM
  4. STATESIDE DEBUT FOR AUDI ROADJET CONCEPT
    Last Post: 15-01-2006, 03:36 PM
