Thread: Passat Brake light unit
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: Passat Brake light unit
    Norfolk
    Andy. When you put the brakes on do the passenger brake and high level brake light come on. If they do it means the fault is only between the drivers side bulb and the previous connector. Are you absolutely sure you don't have 12v when the pedal is pressed.
  2. Re: Passat Brake light unit
    Norfolk
    Quote Originally Posted by more power pls View Post
    hi I have the same problem on my 04 estate (tdi 130) did you find the route of the problem? Its mot time for me soon and I can see some blue scotch lock connectors comming out to play soon if I cant find the source of the fault!!
    Have you lost both brake lighs and the high level light. That's the brake switch. Lost a single unit ? Use a test light to ensure you have power when the pedal is pressed. No power....look for a wire fault. Got power look carefully at the bulb holder.
  3. Re: Passat Brake light unit
    Mar 2007
    Quote Originally Posted by martin1810 View Post
    I've just checked again Martin, now I don't have 12v..... I'm really scratching my head now.
    Somewhere between a rock and a hard place
  4. Re: Passat Brake light unit
    Norfolk
    Are the other brake lights working. If they are you need to trace the wire back to the previous connector and test for 12v there.
  1. 2004 Golf Mk4 1.4 Match - Misfire & Brake Switch Errors.
    By mlilburn in forum Golf MK4 - 1999 - 2004
    Last Post: 26-11-2009, 08:45 AM
  2. auto shutdown of convenience systems
    By bigb in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 29-03-2009, 07:40 PM
  3. Polo brake light fuse problem
    By iandy in forum Polo - Derby - Lupo - Fox
    Last Post: 09-04-2008, 02:12 PM
  4. ABS light on with flashing red brake light
    By P471 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-11-2007, 09:26 PM
  5. Passat Estate High Level Brake Light
    By JRPdark in forum Passat - Archive Topics
    Last Post: 13-09-2006, 12:23 PM
