Thread: Temperature outside -39!!
Results 1 to 9 of 9
  1. Temperature outside -39!!
    Mar 2007
    Im new to all this, i dont know a great deal about cars but i love vw. Ive had 2 polos, a golf a bora and now a passat and im only 21!
    Problem is, the new passat ive just got 2nd hand is great but for some reason both the computer and the climatronic read temperatures around minus 40 all the time!! Whats the problem and how do i fix it??
    be gentle i am new.
    Thanks!
  2. Outside Temperature
    Mar 2007
    Norfolk
    Sounds like the external temperature sensor is faulty. I believe this is located within the front bumper.
    Dan
    VEEDUBYA
    2.0TDI A3 SPORT
    2.0TDI PASSAT SPORT EST.
    May 2006
    Exmouth, Devon, UK. Drives Bonkers Fabia Diesel. Has full VCDS
    Now I know it's been chilly recently, but that's just a bit of exaggeration.
    On my car, the temp sensor is located low down in the front bumper, on the nearside, beside one of the foglight panels. It looks kind of cylindrical with a pointy end.
    Jason - Rather mad Skoda Fabia driver.... Odd whiff of diesel coming from him.
    260bhp Skoda Fabia TDI Dyno Run
    http://www.youtube.com/watch?v=9BvjJjL7Z50
    315bhp Skoda Fabia TDI Dyno Run (2013)
    http://www.youtube.com/watch?v=TOE4nbT5NGY
    Mar 2007
    ah great stuff.
    next issue then. how do i know if its faulty? Obviously itshould be rather than a loose connection and if so, how much and where from is a replacement??
    Thanks for the help so far guys.
    Oct 2005
    Using a 2002 Passat as an example
    Item 9 - Outer temperature sensor - 8Z0820535
    Item 10 - retainer / outer temperature sensor - 8D0820536C
    Ive had this problem myself just a few weeks back. The fault cleared the following day and it hasnt come back as yet, i can only guess that it was because i had given the car a very good wash with loads of jet washing into the front area during that day.
    Have you given your car a good blasting with water recently ?
    Mar 2007
    hi,
    no. only thing is, wjhen i bought it it had been sorn for nearly a year and was kept in a barn. Its in immaculate condition apart from this one problem. And (in ref to pic above) i did try to locate the sensor but no idea! maybe a good jet wash might do the trick?
  8. Outside Temp sender
    May 2006
    Interesting.....
    My outside temp sensor goes 'glong' and shows -20c when driving in heavy rain. Sure sign that the alarm will malfunction for the next 10 days until it all dries out. CCM & under ns front well bone dry though.
    Part of the rich tapestry of Passat ownership.....
    Mike
    Mar 2007
    Cumbria
    You've got water ingress via the pollen filter housing and it running down the wiring loom into grey connector behind the LHF corner kick panel in the LHF footwell.If the car is newish try your local VW dealer as maybe covered under GOOWILL guidelines from VW and mayb repaired F.O.C or VW may contribute some of the repair costs.Get it seen to or will just get worse and cost £££££££'s to fix.
  1. Temperature Sender
    By Coupe16v in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 11-11-2009, 06:19 PM
  2. Temperature gauge not registering
    By A4Sline in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-05-2007, 04:01 PM
  3. temperature outside -39!!!
    By stestroud in forum Archive posts
    Last Post: 24-03-2007, 12:03 PM
  4. tick-over/ temperature
    By ack351 in forum Polo - Derby - Lupo - Fox
    Last Post: 13-03-2007, 06:16 PM
  5. temperature gauge
    By cat69 in forum Archive posts
    Last Post: 10-11-2006, 10:23 PM
