Thread: Electric Window/Mirror trouble!!!
Results 1 to 8 of 8
  1. Electric Window/Mirror trouble!!!
    The Jungle
    Lads and Ladies any help would be greatly appreciated..
    The electrics in the drivers side door of my car(02 Audi A4) are gone, windows, mirrors and safety locking switch, at first i thought it was a fuse problem so i referred back to the manual to get the fuse location and replaced the fuse but they are still not working, I failed an NCT yesterday for only this reason, can anyone shed any light? Do the electrics just go after time? could it be water damage that got into the door panel? can i fix it myself? and if i bring it to a garage is it gonna cost me a fortune???
    Also in case this helps the passenger door electric window isnt working but the little LED/light on the electric window button/switch is illumnated.. The LEDs/lights on the Drivers door are not illumnated..
    Thanks in advance,
    ST
  2. Re: Electric Window/Mirror trouble!!!
    Southern County Softy
    20 Post(s)
    Check the loom where it runs into the door.
    Pull back the rubber sleeve and check for broken wires...
    A4 2.5 tdi QS (mapped)
  3. Re: Electric Window/Mirror trouble!!!
    The Jungle
    Cheers Kite.. tried that just there a few mins ago and all seems to be ok from the door to the car..
    Would it be worth my while taking the Door panel off? Is this a big job..
  4. Re: Electric Window/Mirror trouble!!!
    Dec 2007
    Quote Originally Posted by Spear Thrower View Post
    check again the wires will be broke and hard to see usaly the brown wire pull at then they will split iv had this on quite a few a4's 1st time took me a week to see the broken wires
  5. Re: Electric Window/Mirror trouble!!!
    Had this problem over the weekend. Live and earth wire broken. Canbus wires were ok. I had to give them a slight pull to make sure as teh plastic was holding them together, they had been working from time to time but only making contact because of the pastic. I took the door panel off and ran new wires in so the soldered wires wouldn't be in the flex area. taking the door panel was a little tedious and not obvious where to pull! Best of luck.
  6. Re: Electric Window/Mirror trouble!!!
    The Jungle
    Cheers lads for the input.. I am just wondering is there a "How To" guide on taking the door anel off?
  7. Re: Electric Window/Mirror trouble!!!
    Hi Guys,
    Im having the same problem with the Mrs A4, the central locking works, and the passenger window switch on the drivers side but the drives window and the mirrors dont work at all.
    I replaced the switch yesterday but no luck, Is there any other fuses in the car besides the ones in the side of the dash ?
    Or would it be broken wires ?
    kash
  8. Re: Electric Window/Mirror trouble!!!
    20 Post(s)
    Quote Originally Posted by k17shk View Post
    Hi Guys,
    kash
    Check for broken wires first...
  1. Electric Windows
    By sdk778 in forum 80 - 90
    Last Post: 07-04-2008, 04:27 PM
  2. Replies: 0
    Last Post: 02-04-2008, 02:14 PM
  3. electric windows fail
    By happysnappy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-10-2007, 12:26 AM
  4. Replies: 0
    Last Post: 24-10-2007, 07:38 PM
  5. Front electric windows not working
    By msond in forum 80 - 90
    Last Post: 15-08-2006, 04:00 PM
