Hi Guys
I have recently replaced my normal headlights with a HID Kit, which I bought from HID Direct. The bulbs fit in fine etc, but have a problem when I went to MOT garage to get the headlampe realinged.... I hope someone can help me with this
In the original headlamp of Bora 2001 model, there is a metal shield in front of the bulb - do I have to remove this shield and directly replace with my HID bulb, or leave the metal shield and remove metal shield that came with the bulb and simply fit the bulb only.
Currently I have gone with the second option - when I took it for headlamp adjustment the guy said that light is reflected back because of the metal shield hence I am not getting a pattern.
I am hoping someone has got a solution to my problem - I don't want to loose the bulbs as the light from it is simply brilliant.
Thanks for your help in advance
Kinj
