Thread: Ignition Problem
Results 1 to 8 of 8
  1. Exclamation Ignition Problem
    Mar 2009
    I turn the key and the rev counter needle shoots up and then straight back down again and dies. It happens quite infrequently, but when it does is a nightmare and it won't start for half the day (like today). It seems to do it when there's a been a bit of sun, if that offers any clues.
    Anyone experienced this or know a solution? Any suggestions appreciated.
    Many thanks in advance
  2. Re: Ignition Problem
    Mar 2009
    Did it again this morning! Anyone today know a solution to this?
  3. Re: Ignition Problem
    Dec 2008
    Stockport
    Which engine code is it, please?
  4. Re: Ignition Problem
    Mar 2009
    Quote Originally Posted by BobProperty View Post
    I've just looked on about 10 sites at engine code lists, but none of them list GTi's for some bizarre reason.
    It's a MK3 Golf GTi 2.0, N 1995
  5. Re: Ignition Problem
    Dec 2008
    Stockport
    Quote Originally Posted by theprodigy View Post
    I think that's an AGG. Have you got the handbook? Is there a sticker on the top of the cambelt cover (can't remember if Mk3 GTis have one there)
  6. Re: Ignition Problem
    Mar 2009
    There are two numbers/codes on the cam belt cover:
    ABF 0044 400
    1825
    Hope this is one...?
  7. Re: Ignition Problem
    Dec 2008
    Stockport
    Its the ABF bit, yes. Yours has 16 valves not 8.
  8. Re: Ignition Problem
    Mar 2009
    Does posting this assist with matters in general? I was under the impression you may've been able to help...
  1. Ignition barrel problem?
    By britaxcooper in forum Golf MK3 - 1993 - 1999
    Last Post: 26-12-2007, 07:25 PM
  2. Replies: 6
    Last Post: 21-12-2007, 10:54 AM
  3. Oil Pressure problem
    By j1borman in forum Passat - Archive Topics
    Last Post: 23-01-2007, 10:08 PM
  4. AUDI A6 2.5tdi ignition problem
    By hakolos in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-01-2007, 12:09 PM
  5. possible ignition problem Vento
    By Brucie in forum Vento - 1994 - 1998
    Last Post: 02-02-2006, 11:13 PM
