Thread: My cable aint workin' anyone know why?
Results 1 to 10 of 11
  1. My cable aint workin' anyone know why?
    Dec 2006
    I bought a Vag-Com cable for my Mk4 golf GTI. Well, actually I tell a lie, I got the ebay version.
    The problem I'm getting is with the connection between the car and my laptop. The cable install perfectly on my laptop and plugs into the car port perfectly but..... When i plug it into my car the program acts as if theres nothing on the other end of the cable and tells me there's nothing there despite the fact that the lights come on on the car plug end.
    Did anyone get this problem when they started up?
    Thanks in advance
    Mar 2007
    Cornwall
    Sorry for asking the obvious, but did you switch the ignition before starting the program?
    Dec 2006
    Quote Originally Posted by guyg View Post
    yes, i've tried it from all angles
    car on prior to plugging the cable in and then starting the program
    cable in, program on, ignition on
    ignition on program on, cable in
    and so on...
    still no joy though
    Canada
    Right this needs a little think about, the issue you have is this. when you plug in the usb cable it installs a serial port driver, basically the USB cable is a serial converter.
    What will often happen is the driver will grab the next available com port, which i find is usually com 5 or more.
    the freeware Vag-com uses com ports 1 to 4 only.
    You need to go into device manager on your PC and find the associated device, go into properties and change the port to com4.
    Once thats done. go in to vagcom set the com port to 4 and test.
    Should be ok.
    note: remember which USB port you used as if you plug it into a differnet one it will get configured to a new com port.
    Hopefully thats clear.
    Rob
    Dec 2006
    Ah right, that would make a bit of sense I suppose. I'll try that tonight then.
    Thanks Rob
    Canada
    No problem, let us know how you get on.
    Rob
    Dec 2006
    Quote Originally Posted by onzarob View Post
    Rob
    Hi Rob,
    I checked through my device manager as to which COM port it was using and it was already set to COM4. So I didn't have to change anything. There's still no change in my situation. Any other ideas why it mightn't be working?
    Canada
    You may of dome this but before we go any further.
    Plug in cable...check device manager that it is Com4
    plug into to car, switch ignition on.
    go in to settings in vag-com set com4.
    Click test....
    hopefully all good.
    let me know
    Rob
    Mar 2007
    Cornwall
    It might be worth checking that there aren't any other applications or services running that might be grabbing com4 before VAG-Com has a chance to access the port.
    Some phone/palm/PDA programs like Hotsync/ActiveSync can tie up com ports as can Bluetooth software and drivers - the only com port I had free on my laptop was com2, but this will vary.
    It might be worth switching the driver and VAG-Com to a different port if you have another free [between 1-4].
    Guy
    Canada
    You can see if the other com ports are insue as it will say next toeach of the com port if that is the case.
    Rob
  1. cant get VAG COM to recognise my cable
    By ardasaliah in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-06-2007, 03:53 PM
  2. CD Changer cable
    By Fourbears in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-05-2007, 11:23 PM
  3. Bonnet cable
    By arfsvdub in forum Passat - Archive Topics
    Last Post: 09-05-2007, 04:27 PM
  4. ABS cable
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-04-2007, 04:11 PM
  5. Cable for use with VDS Pro
    By NickW in forum VCDS - General Questions
    Last Post: 10-04-2007, 04:28 PM
