Thread: Audi A4 saloon B7 Rear Bumper Removal
  1. Question Audi A4 saloon B7 Rear Bumper Removal
    Clint1093 Guest
    Can anybody inform me of the best way of removing the rear bumper on my 06 B7 Audi A4 saloon? I am looking to fit rear parking sensors.
    Any info would be great thanks.
  2. Re: Audi A4 saloon B7 Rear Bumper Removal
    Jun 2008
    Marmitehampton
    1. Slacked rear wheel nuts
    2. Jack car up and remove wheels
    3. Remove torx head screws inside wheel arch that hold rear bumper on
    4. Now for the hardest bit. Open the boot.
    5. Remove trim from left and right side of boot
    6. Undo the 4 bolts
    7. Place quilt / towel on floor
    8. The bumper needs releasing from the rear wings. Do this by gently but firmly pulling outwards. The bumper will unclip.
    9. Carefully remove the bumper from the car.
    10. You will see that the rear bumper is marked where the factory fit parking sensor holes would be. Use a 2mm bit to drill a pilot hole then go through with the hole saw from the front. Take care.
    HTH,
    fM
    EDIT: See my post in your other thread.
    2007 Audi A4 2.0 TDI 140PS | S-Line | BOSE | Volterra Leather
    Retrofitted | RNS-E | SDS | Bluetooth | Cruise Control | Parking Sensors | Arm Rest | DIS
  3. Re: Audi A4 saloon B7 Rear Bumper Removal
    Clint1093 Guest
    Thanks for the info very helpful
  4. Re: Audi A4 saloon B7 Rear Bumper Removal
    St. Neots, Cambridgeshire
    Quote Originally Posted by Flakmunky View Post
    6. Undo the 4 bolts
    HTH,
    fM
    You mention removing the trim from left and right sides of the boot, I am having problems finding out how the trims are fixed - don't want to use too much force for fear of breaking any of it. Can you offer any further advice?
    Thanks in advance
    davidj241
  5. Re: Audi A4 saloon B7 Rear Bumper Removal
    Jun 2008
    Marmitehampton
    Ok, revised and more complete notes as I forgot about some screws you need to remove. Sorry.
    I would recommend buying a set of trim removal tools (like these) but they aren't necessary.
    1) Remove the floor of the boot, the spare wheel and the tools.
    2) Remove the 2 bolts towards the rear of the car behind the spare wheel that are holding the piece of black plastic trim on the lip of the boot. Then pull the trim firmly upwards. The trim should release. Check that all of the clips are still in the trim, otherwise use a broad flat bladed screwdriver to prise them out. When refitting this trim ensure the seal is properly positioned.
    3) Remove the carpet from the back of the rear seat by unscrewing the flat black plastic trim screws.
    4) If you have the chrome boot hooks on the floor of the boot remove these otherwise remove the two push button clips on the floor of the boot where the trim comes down and curves round.
    5) Now, in the boot, at the top of the side bits of carpet trim (underneth where the rear wings curve round to the rear deck) there should be another plastic clip you can remove. EDIT: And there is also a metal hook through a slot in the trim.
    6) Now you should be able to firmly pull the trim towards the centre line of the car. The hidden clips are all along the edge of the boot opening. This bit is tricky and you may well end up with the metal clips stuck in the car and no longer on the trim, use a wide flat blade screwdriver to pry them out. You may also break a couple of tabs off the trim (I did) but you could always glue them back on. Note that the left hand side (as you look in to the boot) is a pain because of the 'well'. I couldn't remove the well from the trim whilst it was in the vehicle so the whole lot required some 'waggling' and pulling. Once out the 'well' can be removed which makes refitting much easier. Also if you have the TV system fitted there is an additional mounting bracket which will need to be removed. I don't have this so can't comment.
    7) Slacken rear wheel nuts.
    8) Jack car up and remove wheels.
    9) Remove torx head screws inside wheel arch that hold rear bumper on.
    10) Underneath the vehicle, remove the two (?) Torx screws holding the bottom of the bumper to the vehicle.
    11) Undo the 4 (?) cap nuts on each side.
    12) Place quilt / towel on floor.
    13) The bumper needs releasing from the rear wings. Do this by gently but firmly pulling outwards, away from the side of the car. The bumper will unclip.
    14) Carefully remove the bumper from the car.
    15) You will see that the rear bumper is marked where the factory fit parking sensor holes would be. Use a 2mm bit to drill a pilot hole then go through with the hole saw from the front. Take care. I would invest £20 in a proper hole saw for this job.
    Hope this helps. Paint the sensors otherwise they will look crap! I kept popping my sensors in the oven (on very low ~50 degrees) for 10 minutes or so to help speed up the curing time in between coats. This also meant I could fit them in a day. I bought the Cobra Parkmaster sensors. These are really good. The period between the beeps is infinitely variable rather than the cheaper systems that just have four different intervals. eg. instead of Beep........Beep....Beep..Beeeeeeeeeeeeeeeep the Cobra system goes Beep........Beep.......Beep......Beep.....Beep.... Beep...Beep..Beep.Beeeeeeeeeeeeeeep. Does that make sense?! The Cobra system doesn't have a little screen, either, which IMO is a 'Good Thing'.
    4 0 0
  6. Re: Audi A4 saloon B7 Rear Bumper Removal
    Mar 2009
    Wiltshire
    Jello Clint1093,
    I'm about to fit a towbar and this means removing the rear bumper, just like you need to do.
    I found some very good instructions, with a video, on the tow bar fitting websites such as www.witter-towbars.co.uk. However, as Flakmunky says, you do need to put something on the ground to prevent the bumper getting scratched.
    Good luck!
  7. Re: Audi A4 saloon B7 Rear Bumper Removal
    Jan 2009
    Ilkley, West Yorkshire, United Kingdom
    Great reply Flakmunky.
    I'm a tad confused about why steps 1 - 6 are necessary, tho? Are there some bumper fasteners hidden behind the trim?
  8. Re: Audi A4 saloon B7 Rear Bumper Removal
    Quote Originally Posted by Clint1093 View Post
    Wow, you beat me to it, I was just going to ask the very same question. So many thanks - hope you manage to fit your sensors allright. BTW, what make of sensor are you using?
  9. Re: Audi A4 saloon B7 Rear Bumper Removal
    Jun 2008
    Marmitehampton
    You can always click people's Rep to let them know you appreciate their help!
  1. Replies: 10
    Last Post: 17-11-2015, 10:51 PM
  2. "How To" remove the Rear Bumper on an A3
    By djgilson in forum Audi
    Last Post: 25-05-2014, 08:04 PM
  3. Replies: 1
    Last Post: 14-12-2009, 11:49 AM
  4. The new generation Audi A3
    Last Post: 28-04-2008, 07:04 PM
  5. ENHANCED SPECIFICATION FOR 2006 AUDI A4 AND A6 RANGES
    Last Post: 12-12-2005, 09:07 PM
