Thread: Gear Selector Problem '96 TDi
  1. Gear Selector Problem '96 TDi
    Mar 2009
    Newton Swansea
    I have a problem selecting first & reverse gears, there is too much fore & aft movement in the gear lever. Problem is at the gear selector arm on the gear box it has a lot of free movement seems the the trouble is inside the gear box either the lug on the selector shaft is worn or the selector forks. It has done a lot of miles 258000+! Problem seem worse since having a new clutch fitted today.
    Any one had experience of this?
  2. Re: Gear Selector Problem '96 TDi
    Apr 2009
    broughshane
    Quote Originally Posted by keithot View Post
    i have a problem selecting first & reverse gears, there is too much fore & aft movement in the gear lever. Problem is at the gear selector arm on the gear box it has a lot of free movement seems the the trouble is inside the gear box either the lug on the selector shaft is worn or the selector forks. It has done a lot of miles 258000+! Problem seem worse since having a new clutch fitted today.
    hello keith
    try this one ebay item number 390040505494
    i did on mine made it wright and sorted my problem same as yours just wear and tear
    good luck rickie
  3. Re: Gear Selector Problem '96 TDi
    Mar 2009
    Newton Swansea
    Thanks for reply Rickie, unfortunately that repair was done a year or two ago, this is the gearbox that is passed its sell by date! I have found a good low mileage box in my local breakers (& a few other bits) & hope to fit it asap!
  4. Re: Gear Selector Problem '96 TDi
    Jul 2008
    Have you tried adjusting the setting on the top cable connecting to the selector , i found after replacing my gear linkage that if this nut is not in the correct place it can make finding gears difficult .
  5. Re: Gear Selector Problem '96 TDi
    Mar 2009
    Newton Swansea
    Yes I did tweak the adjuster, I can get all the gears just waaay too much fore & aft movement.
  6. Re: Gear Selector Problem '96 TDi
    May 2009
    Southend on sea United Kingdom
    I solved my Tdi gear problem by replacing the selector connection bolt with a longer one with a lock nut. I initially thought my gearbox is playing up. The positions where you are locking the selector arm are quite sensitive. I had to try a couple positions before I had found the correct position.
    A good starting point is to loosen the bolts and found the neutral position on the gearbox by moving the selectors by hand. Ask someone to hold the gear lever secure in the neutral position right in the middle. Now you can tighten the selectors and test your gear shifts. From here you should not move it more than 3mm at a time if it needs adjustment.
    Make sure that you can selects all 5 gears including reverse, as for example when you can not select 2, you adjust it and by the time you can select 2,.... it can mean that 5 or reverse are now out of synchronisation.
    When you find the right position, lock it secure.
    Lubricate the selector and the gear shift should feel like new.!!
  7. Re: Gear Selector Problem '96 TDi
    Mar 2009
    Newton Swansea
    Your are right about it being sensitive VW use a special jig to hold the gear lever in a set position while the selector is adjusted. I have got the new box & selector working pretty well now - maybe not perfect yet but getting close!
  1. VW Polo 1.9 Tdi Gear Box Problems
    By Boz in forum New Member Introductions
    Last Post: 04-01-2008, 07:24 PM
  2. Replies: 0
    Last Post: 21-04-2007, 05:47 PM
  3. Audi 80 TDi gear ratios
    By andymc in forum 80 - 90
    Last Post: 26-03-2007, 05:10 PM
  4. PRICES OF NEW TOUAREG ANNOUNCED AHEAD OF MARCH LAUNCH
    Last Post: 02-01-2007, 08:22 PM
  5. NEW TOURAN AVAILABLE TO ORDER NOW AHEAD OF JANUARY LAUNCH
    Last Post: 04-12-2006, 08:10 PM
