Thread: Switched Ignition Feed
  1. Switched Ignition Feed
    Dec 2007
    Hello Chaps,
    Re an earlier post, does anyone know of a reliable switchable ignition feed, from either the driver or passenger side? As im taking apart the car to try and fit this stereo, I was hoping to find one in there to avoid running something from the fuse box?. Can anyone also tell me that if in doing this it avoids the need for a can bus adaptor? Thanks
  2. Re: Switched Ignition Feed
    May 2008
    Fusebox is the best (and safest!) way to find a suitable ignition feed.
    It only takes ten minutes to run a wire to the back of the stereo.
  1. Stereo ignition sense problem
    By andym82 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-05-2007, 11:50 AM
  2. Stereo Ignition Feed
    By paulr29 in forum Passat - Archive Topics
    Last Post: 03-05-2007, 09:33 AM
  3. Noise after air-con / ignition switched off!
    By paul46 in forum Archive posts
    Last Post: 01-04-2007, 02:30 PM
  4. vw golf 1988, no current from ignition coil?
    By Nelson in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-12-2006, 10:50 AM
