Thread: Running Rough and Low on Power
  1. Running Rough and Low on Power
    Nov 2006
    Norwich, UK
    Hello guys,
    Not been around for a while as work has been crazy and not really been using my Audi but hopefully some people remember me!. Anyway I was driving out last night about 70 when I seemed to lose power and most dash warning lights came on, I idled and came to a stop off the main road, got towed home etc. This morning I managed to find my vagcom bits and plugged the old girl in and came up with the following errors;
    Chassis Type: 8E - Audi A4 B6
    Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
    Address 01 -------------------------------------------------------
    Controller: 8E0 907 557
    Component: 2.0L R4/5VS 0006
    Coding: 0011501
    Shop #: WSC 63351
    8 Faults Found:
    17544 - Fuel Trim: Bank 1 (Add): System too Lean
    P1136 - 001 - Upper Limit Exceeded
    16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
    P0116 - 008 - Implausible Signal - Intermittent
    16825 - EVAP Emission Control Sys: Incorrect Flow
    P0441 - 001 - Upper Limit Exceeded - Intermittent
    17953 - Throttle Valve Controller: Malfunction
    P1545 - 002 - Lower Limit Exceeded - Intermittent
    17967 - Throttle Valve Control part (J338): Fault in basic settings
    P1559 - 008 - Implausible Signal - Intermittent
    17987 - Throttle Actuator (J338): Adaptation Not Started
    P1579 - 001 - Upper Limit Exceeded - Intermittent
    17947 - Clutch Pedal Switch (F36): Implausible Signal
    P1539 - 004 - No Signal/Communication - Intermittent
    Readiness: 0000 0000
    Address 03 -------------------------------------------------------
    Controller: 8E0 614 517
    Component: ABS/ESP front D620
    Coding: 04275
    Shop #: WSC 06435
    1 Fault Found:
    18256 - Please check DTC Memory of Engine Controller
    P1848 - 35-00 - -
    Address 08 -------------------------------------------------------
    Controller: 8E0 820 043 B
    Component: A4 Klimaautomat 0506
    Coding: 00000
    Shop #: WSC 63351
    1 Fault Found:
    01273 - Fresh Air Blower (V2)
    30-00 - Open or Short to B+
    I am pretty sure the fresh air blower is my aircon and the Engine Coolant Temp. Sensor is the famed green topped one and both were intermittent before yesterday. The others though are baffling me a touch!
    I have had a quick look on the rosstech wiki but can find nothing conclusive above pull everything apart until you find what is wrong.
    If anyone can help me before I get back to her tonight I would be most grateful.
    Thank you
    p.s it is a petrol.
    Cheers Stu
  2. Re: Running Rough and Low on Power
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Hi Stu,with as many faults as that you would think it was a power interuption.All fuses and relays ok?or a multi plug of an ecu?Let us know if you get it!
  3. Re: Running Rough and Low on Power
    132 Post(s)
    1979 Post(s)
    Check fuse 7 but I would clear them and see what comes back, it may be water in the ECU. Have you had a blocked plenum chamber?
  1. 1.8t a3 running rough poor idle no power???
    By djglovehead in forum Audi A3 - Archive Topics
    Last Post: 10-04-2007, 06:33 PM
  2. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
  3. The New Audi A6 All Road, at home on all roads and tracks
    Last Post: 29-04-2006, 06:00 PM
  4. At home on all roads and tracks - Audi A6 allroad quattro
    Last Post: 05-03-2006, 07:53 PM
