Thread: Electric window mechanism jammed TDI sport Passat 52 plate
  1. Electric window mechanism jammed TDI sport Passat 52 plate
    Mar 2007
    My passenger electric window mechanism has broken. Just makes a horrid grinding sound when I press the button.
    Does anyone know how I can safely (minimising damage) remove the door panel to get to the mechanism?.
    Apr 2007
    Hello - did you get anywhere with this?? I have EXACTLY the same problem!!
    Spoke to my old man, he says the window has come off the runners?? I'm thinking that the only solution is to take the door off and have a good look around.
    I had a look in the HAYNES manual, it mentions about relay or fuse gone, but I figure that if they where gone there would be no power at all??
    Unless anybody can suggest anything - looks like I will need to take the door trim off to investigate.
    Crowbar here I come....?
    Apr 2007
    Quote Originally Posted by Tony31 View Post
    should be 6 screws(torques screws)that need to come out then panel should pop out with little force..you might need to take out plastic cover from around door handle(depending on model)to get it of.mind the wiring inside though,sometimes it is short and can break...
    Mar 2007
    Cornwall
    A recurring theme with Golfs and Passats - have a look at
    https://www.vwaudiforum.co.uk/forum//...ead.php?t=6831
    There's a link on the above thread to a full stripdown and replacement of the regulator mechanisms.
    Guy
    Apr 2007
    warrington
    sorry to say it mate ive see this problem many times if it sounds like glass crunching then a new one is the only way to solve it ive worked on car glass for 17 years trust me ive seen it all if you need more info let me know.dont worry about the panel i have tech sheets to help
    Apr 2007
    warrington
    its not as scarey as it looks.......!
  1. Electric Window Motor
    By alperin in forum Early Passat Forum - Pre 97
    Last Post: 04-06-2007, 09:02 AM
  2. Electric Window
    By LLX in forum Polo - Derby - Lupo - Fox
    Last Post: 20-04-2007, 11:49 PM
  3. electric window
    By sumanb82 in forum Audi A3 - Archive Topics
    Last Post: 14-04-2007, 08:56 AM
  4. Passat Electric Window Problem
    By Brianm in forum Archive posts
    Last Post: 05-02-2007, 12:30 PM
  5. VW Polo 1.4 Sport '02 plate
    By trigger in forum Polo - Derby - Lupo - Fox
    Last Post: 13-01-2006, 07:05 PM
