Thread: Allroad susspension probs
  1. Allroad susspension probs
    Mar 2009
    Hi there, just bought a used all road, and discovered front susspension is not working how it should.. Compleatly collapsed on the drive home. had to keep stopping and re starting engine to get it pumped back up again. Managed to get it up to level 3 which worked fine till i got above 60mph where it progressively dropped untill front end was on the deck again..? Leave it on level 3 over night (fine) anything lower and i wake up with it on the deck again.. Any thoughts
  2. Re: Allroad susspension probs
    Jun 2007
    The model and year would be good. Did you buy it from a dealer, if so take it back to get it fixed. Regards Peter
  3. Re: Allroad susspension probs
    Cheshire, or my A6
    Its probably a leaky air bag. As Peter says if it has been bought from a dealer just recently then I'd take it back, the air bags can be expensive.
  4. Re: Allroad susspension probs
    Mar 2009
    Quote Originally Posted by Peter D View Post
    Audi alroad 2.5 tdi auto with 103,000 miles.. Bought privately on Monday, got an hour into journey before prob happened..!
  5. Re: Allroad susspension probs
    Mar 2009
    Quote Originally Posted by paul b View Post
    Taken it to main dealer yesterday, and it worked fine all the way there with no probs, untill i went to leave and low and behold it was on the floor again..
  6. Re: Allroad susspension probs
    Jun 2008
    Hi
    Read this thread.
    Post in there m8, we are all Allroad owners with simular problems.
    Lee
    Last edited by snugglebum; 28-03-2009 at 10:51 PM. Reason: cant spell after a few beers lol
  7. Re: Allroad susspension probs
    Ayrshire, Scotland
    18 Post(s)
    Quote Originally Posted by CHEEZIE View Post
    Sounds like a leaking airbag, similar to mine as the thread snuggle bum shows is where we have been problem solving others, or search for other posts by me, Mine would leak quickly on level 1 & 2 but on level 3 it would stay there overnight. the bag was perished and at level 1 & 2 it leaked on the crease. do not run the car on level 1 or 2 as it will burn out the compressor, or may be too late!!. On level 3 you can drive up to a speed 55MPH after this the car auto lowers to level 2 then the compresor will run, if you have to use the car I would strongly reccomend only use at level 3.
    To clarify you have a leaking bag, raise to level 4 and soak the suspect suspension air bag with soapy water, if its leaking you will get bubbles forming. you then have 3 options:
    1. Some have tried tyre slime, use for tyre punctures, it might make it last a few months, (i don't recommend this)
    2. you can go to audi £400 +Vat Part only, or fitted guess around £750+
    3. or Arnot in the USA replacement £300 inc shipping to UK. The options arent great but if you are DIY person to change is not too difficult with the right tools, i recently fitted the Arnott option and am happy with the results, a few others are following with the same leakings issues.
    1st check the bag is leaking as above before making any decisions!!!
    regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  1. New Audi A4 Allroad Quattro Heads For The Hills
    Last Post: 16-02-2009, 10:04 PM
  2. New Audi A4 Allroad Quattro Heads For The Hills
  3. The New Audi A6 All Road, at home on all roads and tracks
    Last Post: 29-04-2006, 06:00 PM
  4. New Audi A6 allroad quattro ready to tackle British soil
    Last Post: 05-04-2006, 08:13 PM
  5. At home on all roads and tracks - Audi A6 allroad quattro
