Thread: Instalation of cruise control-does existing control modul support it?
  1. Instalation of cruise control-does existing control modul support it?
    Mar 2009
    Montenegro
    13 Post(s)
    HI,
    I have intention to install a cruise control on my Audi A4 Avant 1.9 tdi 2004 year. This evening I had taken a few pictures of control unit (J 527) and his part number is : 8E0 953 549 S. Does this control unit support cruise control? By the way, my car does not have multifunction steering wheel neither phone integration. I try to count the wires which enter into control unit (without disconecting, it was difficult to count) and there are 12. Do I need to add some other wire from unit to some other place (for example engine control unit) and where or I need only to add a cruise control handel and to reprogram engine control unit?
    Thanks for replies.
  2. Re: Instalation of cruise control-does existing control modul support it?
    May 2007
    knee deep in clunge
    14 Post(s)
    no index s will not support cruise function
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=52211
  3. Re: Instalation of cruise control-does existing control modul support it?
    Mar 2009
    Montenegro
    13 Post(s)
    Thanks for Your prompt reply. I have just read Your post and I do not understand fiting of wire from dash (blue conector) to earth, is this only who wants to instal on board computer handel? I have on board computer (even in colour), so for instaling cruise control (only the handel) I need :control unit with index N, handel and steering column lower cowling and to recode control unit with vag com, as I understand Your thread?
  4. Re: Instalation of cruise control-does existing control modul support it?
    May 2007
    knee deep in clunge
    14 Post(s)
    Yes ignore the on board computer part if you already have it.
    Fit the steering column electrics index N and the lower cowling plus the switch then code the steering column electrics for cruise and enable the engine ecu for cruise.All the info for setting the cruise up with vag com is present on my post
  5. Re: Instalation of cruise control-does existing control modul support it?
    Mar 2009
    Montenegro
    13 Post(s)
    Thank You very much! I admire to You. I will try to collect all items that I need for CCS and try to install.
  6. Re: Instalation of cruise control-does existing control modul support it?
    May 2007
    knee deep in clunge
    14 Post(s)
    No problem Novica,if you require further assistance just ask
  1. Cruise Control
    By Grant620 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-12-2008, 02:02 PM
  2. cruise control
    By nug402 in forum Golf MK5 - 2004 - 2009
    Last Post: 21-08-2008, 07:11 AM
  3. Cruise Control Again
    By murtaghp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-07-2008, 09:40 AM
  4. How To Cruise Control
    By kevlo99a4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-05-2008, 09:07 PM
  5. Cruise Control / Climate Control
    By Cian_ie in forum Archive posts
    Last Post: 27-01-2008, 08:47 AM
