Thread: 2005 Passat saloon parking sensors issue
  1. 2005 Passat saloon parking sensors issue
    Mar 2009
    Hi, I am experiencing an intermittent problem with my 2005 passat saloon. I have rear parking sensors which seem to work as expected 70% of the time. However, sometimes when I put the car in reverse, instead of a beeping sound, I am getting a consistent noise (i.e. no beeps, just a constant squeal from the sensors). This is happening when parked away from any objects and the sensors are clean. Can anyone help?
  2. Re: 2005 Passat saloon parking sensors issue
    Merseyside
    I had the same problem with my car; strangely mine would only work correctly when the car was soaking wet. A fault code will be stored which identifies which sensor is faulty (i.e. middle left, outer left etc) so best to get someone to do a scan with VAG COM. With my car, I cleared the code and swapped sensors to check that the fault was with the sensor and not the wiring loom. I then read the fault codes again which indicated it was a faulty sensor. I then tried to take the sensor apart which was a bad idea as I completely destroyed it!! The new sensor cost me approx £60 from VW and then another £10 for the local bodyshop to paint it.
    The sensors are straightforward to remove, see my post on the following thread.
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=64546
  1. Parking Sensors on 01 Passat
    By Redgrunter in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-11-2008, 03:23 PM
  2. Parking Sensors-2005 (55) VW Passat 2.0TDi SE
    By Raf in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-09-2008, 08:19 PM
  3. Retro fitting parking sensors on A4 Sline saloon
    By SINGHY in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-05-2008, 07:53 AM
  4. Passat parking sensors
    By Michelin in forum Passat - Archive Topics
    Last Post: 17-09-2007, 08:17 PM
  5. passat parking sensors
    By schoey1 in forum Passat - Archive Topics
    Last Post: 31-05-2007, 01:18 PM
