Thread: creek on front/back end + knock on back end
Results 1 to 9 of 9
  1. creek on front/back end + knock on back end
    Feb 2009
    Hi, just wondered if any one can help?
    I have a W plate bora 1.9pd tdi (115 bhp) and i've got a creek on both front and back end but mainly when I brake and also when I go over speed bumps I get a knocking which you can really feel on your back side!
    Can any one give me any tips on what I need doing and how much?
    I have been told that I should try spraying WD40 on the rear/front bushers but i'm not sure if I should or not
    Many thanks!
  2. Re: creek on front/back end + knock on back end
    135 Post(s)
    2026 Post(s)
    WD40 will not cure your problem! The knock on the rear is probably worn rear axle mounts which feel as though someone has kicked you under the seat and the front is probably a failed anti roll bar which means a new bar and inner bushes.
  3. Re: creek on front/back end + knock on back end
    Feb 2009
    Nice one. Just wondering how much will all this cost?
    Thanks.
  4. Re: creek on front/back end + knock on back end
    May 2008
    Depends on the labour rate you are paying, its very difficult to quote accurate prices. Ring a few places for some Quotations.
    I had exactly the same things go wrong with my old Bora TDi - luckily they were covered under warranty but the fix was exactly as Crasher describes above.
  5. Re: creek on front/back end + knock on back end
    Feb 2009
    nice one boys. When I get it diagnosed at garage Iwill let you know.
  6. Re: creek on front/back end + knock on back end
    135 Post(s)
    2026 Post(s)
    The rear axle bushes are a pain to remove without the right tool but getting the new design in is quite a lot easier, I think we charge about £250 all in including bleeding the brakes although not everyone opens the rear brake circuit but I do as I fin the hoses are put under worrying stress otherwise. If the rear axle bushes are removed without the correct tools, I have seen the rear axle bush area severely damaged and don’t let someone talk you into non standard bushes either. We have just done forum user TDIborasams rear bushes and the location area was a mess that we had to clean up and smooth off and we were removing the sold rear bushes that had been fitted. I sell them but I don’t like them. The front roll bar parts cost just under £100 and it takes under two hours to do the job so typically around £200 all in.
  7. Re: creek on front/back end + knock on back end
    Sep 2007
    Essex boy in Suffolk
    Crasher,
    Why dont you like the rear poly bushes?
    Graham
    Still pretending to know stuff.
    Golf 6 .:R
    Corrado 20vT - BBS RCs, Leather, Bremo's, TFSI and DSG
  8. Re: creek on front/back end + knock on back end
    135 Post(s)
    2026 Post(s)
    They take away the passive rear steer and are harsh.
  9. Re: creek on front/back end + knock on back end
    Apr 2007
    As Crasher mentioned above, amongst a lot of other work, he has put standard bushes back onto the rear axle for me. The powerflex ones were truely dreadful....noisy, and VERY harsh.
  1. Sharan Dim lights not working front and back HELP
    By taaj in forum Touran - Sharan - Caravelle
    Last Post: 17-03-2009, 08:34 PM
  2. Front & Back Power Ratios - Quattro
    By Harrts in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-08-2008, 03:01 PM
  3. passenger floor back+front soaked!!
    By recreation in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-01-2008, 08:30 PM
  4. A4 TDi Sport Ride Height - different front / back
    By RidwarePhil in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-01-2008, 08:24 PM
  5. (Heater control) Its all back to front
    By pussypassat in forum Passat - Archive Topics
    Last Post: 11-12-2006, 07:48 PM
