Thread: A3 Bluetooth
Results 1 to 10 of 16
  1. A3 Bluetooth
    GV8 Guest
    Hi Guys,
    I have a 2008 A3 with a dash mounted phone holder but only use the bluetooth facility as I don't have the steering wheel controls. I want to buy a cradle for the dash mount but have read in the hand book that 'many' phones disconnect from bluetooth when inserted in the holder. Does anyone know anything about this as I don't want to shell out £100 if the bluetooth doesn't work when the phone is in the cradle??
  2. Re: A3 Bluetooth
    Sep 2008
    Buckinghamshire
    Quote Originally Posted by GV8 View Post
    Hi Guys,
    I have had bluetooth and a cradle on A3's I have had and not had a problems during my ownership
    Current - Audi A3 Sportback 1.8T Sline
    Gone - Audi S3 Sportback Black Edition, Audi S4 Saloon,
    Why not join the Audi A3 Owners Club
  3. Re: A3 Bluetooth
    May 2007
    knee deep in clunge
    14 Post(s)
    When the phone is in the cradle you dont use the bluetooth as the phone is connected through the cradle.
    Retro fit mfsw
  4. Re: A3 Bluetooth
    GV8 Guest
    Thanks one man.
    A8 - I don't have steering controls so i cannot use the mount other than for charging can I?
  5. Re: A3 Bluetooth
    GV8 Guest
    One man - what make was your phone used in the A3?
  6. Re: A3 Bluetooth
    May 2007
    knee deep in clunge
    14 Post(s)
    Ok i will explain
    If you use the cradle then make sure your phones firmware is valid,because the cradle is connected direct then there is no need to use the blue tooth as the phone prep will connect through the cradle as will the aerial.
    http://accessories.audi.co.uk/access...ccessoryId=620
    gsm phone list and cradle part numbers
    Generation II
    phone cradle part number
    Apple iPhone8 8P0 051 435 GP4
    BENQ Siemens C45 8P0 051 435 AP
    ME45 8P0 051 435 AP
    S45 (i) 8P0 051 435 AP
    M50 8P0 051 435 AP
    MT50 8P0 051 435 AP
    S55 8P0 051 435 CJ
    M55 8P0 051 435 CJ
    C55 8P0 051 435 CJ
    C65 8P0 051 435 AT
    CX65 8P0 051 435 EG
    M65 8P0 051 435 EG
    S65 8P0 051 435 ED
    SP65 8P0 051 435 ED
    S68 8P0 051 435 EH4
    CX70 8P0 051 435 EG
    C75 8P0 051 435 DR
    CX75 8P0 051 435 DJ
    M75 8P0 051 435 DK
    S75 8P0 051 435 FB
    Motorola V300 8P0 051 435 DD
    V400 8P0 051 435 DD
    V500 8P0 051 435 DD
    V525 8P0 051 435 DD
    E550 8P0 051 435 DD
    V550 8P0 051 435 DD
    V600 8P0 051 435 DD
    V620 8P0 051 435 DD
    V635 8P0 051 435 DD
    Nokia 3100 8P0 051 435 AA
    6020 8P0 051 435 FT
    6021 8P0 051 435 FT
    6100 8P0 051 435 CM
    6151 8P0 051 435 GG
    6210 8P0 051 435 BQ3
    6220 8P0 051 435 Q
    6230 8P0 051 435 GC
    6230i 8P0 051 435 GC
    6233 8P0 051 435 GE
    6234 8P0 051 435 GF
    6280 8P0 051 435 FS
    6288 8P0 051 435 FS
    6300 8P0 051 435 FQ4
    6310 8P0 051 435 BQ
    6310i 8P0 051 435 BQ
    6600 8P0 051 435 AG4
    6610 8P0 051 435 CX
    6820 8P0 051 435 AD
    7210 8P0 051 435 CX
    7250 (i) 8P0 051 435 CX
    E50 8P0 051 435 FF4
    E60 8P0 051 435 GD4
    Sony Ericsson T610 8P0 051 435 L
    T630 8P0 051 435 L
    K510i 8P0 051 435 FK4
    K610i 8P0 051 435 FJ4
    K750i 8P0 051 435 EN7
    K800i 8P0 051 435 GM4
    K810i 8P0 051 435 GM4
    W700i 8P0 051 435 EN7
    W800i 8P0 051 435 EN7
    W810i 8P0 051 435 EN7
    If you retro fit mfsw then buy a battery charger for the phone and plug it into the cig lighter as blue tooth saps the phones battery charge level
  7. Re: A3 Bluetooth
    GV8 Guest
    Thanks A8 - I'll order the cradle and have a go.
  8. Re: A3 Bluetooth
    May 2007
    knee deep in clunge
    14 Post(s)
    You could always buy the rsap adapter (not cheap)this will convert phone prep low to prep high if your phone is rsap type.
    This will kill two birds with one stone as it will reduce battery discharge and allow full blue tooth conectivity
    http://accessories.audi.co.uk/access...essoryId=10632
  9. Re: A3 Bluetooth
    Sep 2008
    Buckinghamshire
    Nokia 6021 - I use in my S3 now and it's fine
  10. Re: A3 Bluetooth
    May 2007
    knee deep in clunge
    14 Post(s)
    more info on the rsap
    The Bluetooth Remote SIM Access Profile (rSAP) cradle adaptor is an enhancement of the factoryfitted
    option "Mobile phone preparation - Low". It enables mobile phone handsets to connect via
    Bluetooth Remote SIM Access Profile (rSAP) in the same way as handsets connect to the factoryfitted
    option "Mobile phone preparation - High".
    The Bluetooth rSAP adaptor is fitted to the same connection as all other adaptor cradles (either on
    the dashboard or in the front centre armrest). The mobile handset is then connected to the rSAP
    cradle via Bluetooth. When handsets are connected, the cradle enables the use of the external GSM
    car antenna and deactivates the handset antenna in order to minimise GSM radiation in the car and
    handset battery consumption. The handset is put into standby mode so battery power drain is
    minimal.
    Once connected, the cradle connects to the handset automatically and details of up to four handsets
    can be saved. Only handsets with Bluetooth rSAP functionality are compatible with this cradle. Details
    of mobile handsets that are compatible with rSAP can be found on audi parts
    Customer Benefits The rSAP cradle adaptor is flexible so can be used with a variety of different handsets. This
    makes it future proof for compatibility with new handsets “Mobile phone preparation – Low” already has a Bluetooth connection but this only operates in a
    mode called “Hands Free Profile”. This means that although calls can be made and received using
    the car, the phones antenna and battery are operating at full capacity when making and receiving
    calls. The rSAP cradle adaptor uses the cars external antenna and power supply to make and
    receive calls which improves call quality and reduces handset battery consumption.
    Part Part
    Bluetooth rSAP
    cradle adaptor
    8P0051440
  1. BLUETOOTH CAR KIT NOW FITTED -- - NOKIA CK-7W Bluetooth Car Kit
    By RickT in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-01-2011, 10:12 AM
  2. Bluetooth
    By p1lts in forum In Car Entertainment
    Last Post: 12-03-2009, 08:38 PM
  3. Bluetooth
    By Stewart_low in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 19-01-2009, 04:46 PM
  4. Question Will TomTom 540 bluetooth sync with A4 bluetooth phone prep 2nd Gen
    By foxyrider in forum In Car Entertainment
    Last Post: 14-01-2009, 11:39 AM
  5. Bluetooth car kit
    By Michelin in forum Golf MK4 - 1999 - 2004
    Last Post: 04-05-2008, 03:01 AM
