Thread: ABS and EPS lights stay on
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: ABS and EPS lights stay on
    #11
    132 Post(s)
    1980 Post(s)
    Quote Originally Posted by caldirun View Post
    Fitting with the pedal depressed was the problem
    Which is why I asked the qestion
  2. Re: ABS and EPS lights stay on
    #12
    May 2008
    Guys Im going nuts over this!!! Fitted a second new switch but no change brake lights still not working but high level brake light does - and always has. Are both lights on the same switch?
  3. Re: ABS and EPS lights stay on
    #13
    132 Post(s)
    1980 Post(s)
    Was this switch also from GSF? I think they may be selling the old design which are fitted with the pedal up, not pressed. The brake light switch has two circuits. The circuit for the lights is fed from fuse 13 via a red/yellow wire and this is switched onto the red/black wire which feeds all three brake lights. If you jump across these two wires at the switch’s plug, all the lights should come on, if they don't, the problem is with the switch.
  4. Re: ABS and EPS lights stay on
    #14
    Norfolk
    Quote Originally Posted by wheelywonderful View Post
    High level and wing brake lights are all same circuit so brake switch should be ok, unless it is limiting current supply. You may have a faulty wire connector especially if you have ever had wet carpets. I would start at the rear brake lights and test for 12v when someone presses the brake pedal. Then work forwards following the wires behind the trim. Check for 12v each time you find a connector.
    When you press the brake pedal do any of the other rear lights flicker or gow, even a little.
  1. Question Sharan dashboard lights stay on
    By PippyM in forum Touran - Sharan - Caravelle
    Last Post: 07-01-2009, 07:20 PM
  2. A4 Reversing lights stay on!
    By chekers in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-03-2008, 08:52 PM
  3. Interior Lights Stay on in Audi A6 Avant
    By darkskies in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-10-2007, 04:08 PM
  4. Help! Bora Automatic- reverse lights stay on when in drive!
    By biscuitclaire in forum Bora - 1998 - 2005
    Last Post: 01-08-2007, 08:07 PM
  5. Courtesy Lights Stay on?
    By Ruby in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-07-2007, 12:23 PM
