Thread: Rear washer
  1. Rear washer
    Mar 2007
    Near Whitby, N.Yorks
    The rear washer jet is blocked, I have cleaned the nozzle but it would seem to be deeper down the jet,the pumps working ok, how does the jet come out of the spindle, is it a long plastic jet as on the Golf and are they prone to snapping if you try to pull them out. Advice please thanks
  2. yes
    May 2007
    yes, put a soft cloth over the plastic shroud that covers the washer jet and pull it off with pliers (gently). You can then pull the jet out with pliers, it just sits in a sleeve in the the pump housing.
    According to my colleagues (Audi technicians) all older A3 rear wipers go wrong. Apparently the pipes can also blow themselves away from the various unions, and the trick is to look for puddles
    1. under the passenger side of the engine (pipe union below plastic battery shroud from main washer pump).
    2. In passenger side boot compartment (under CD changer if fitted), where the insulation foam just soaks the fluid up.
    3. Inside tailgate panel itself - spot the drips from it.
  1. Golf MK IV rear washer
    By amethyst in forum Golf MK4 - 1999 - 2004
    Last Post: 22-05-2009, 03:46 PM
  2. A6 Avant rear washer
    By agsy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-05-2009, 09:15 AM
  3. Rear washer jet?
    By AWH in forum Chat - Completely Off Topic
    Last Post: 01-11-2008, 02:40 PM
  4. Help please Re: Rear washer jet.
    By Big_E in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-06-2007, 12:29 PM
  5. Washer fluid into car
    By Sky in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-03-2007, 12:43 PM
