Thread: Cruise control
Hybrid View
  1. Cruise control
    Mar 2007
    Is it a complicated job fitting cruise control to M1 TT 2002 The stalk sells at £32 at VAG parts. But where do you buy the wiring loom needed,and does the system have to be reset up or will everything registar and work when all the componants are fitted.AUDI dealer says they have the wiring made up.(where)they wont tell me.Plus they want £350 to do the job,which they say takes 1-2 hours.
    7 Post(s)
    If your in the London area, there is a bloke on e-bay who will supply and fit all-in for £150
    Top bloke, did mine, his user name is Hazydayz.
  3. Re: Cruise control
    Further to this does anybody know the details of what to do? i don't really fancy paying somebody £150 when I can do it myself, but I need to know that apart from the switch and the loom, is that all of the parts you need? I have been given some numbers for the connections between the bulkhead plug and ECU - has anybody done this, and if so can you confirm which numbers off of the ECU plug go to where on the bulkhead plug?
  4. Re: Cruise control
    That's what I'm trying to find out. I've got all the parts and I've made up the appropriate parts for the loom, but I need to know the pin numbers. I'm paying somebody £100+ for something that I can do myself!!
  5. Re: Cruise control
    135 Post(s)
    2036 Post(s)
    The harness is only £22 genuine. What engine code and car do you have Steve? Do you have a registered version of VAG-COM?
  6. Re: Cruise control
    It's a "BAM" engine code in a 2001 1.8.
    The only harness I need is from the bulkhead connector to the ECU - but I can make this myself (previous typo!) provided I can find out which cables go to where.
  7. Re: Cruise control
    Jul 2007
    Sunny Buckinghamshire
    Quote Originally Posted by Steve 509 View Post
    I think you will find all you need to know here> http://www.golfmk4.co.uk/cruise_control.htm
  1. Cruise Control / Climate Control
    By Cian_ie in forum Archive posts
    Last Post: 27-01-2008, 08:47 AM
  2. Cruise Control
    By fozzie in forum Passat - Archive Topics
    Last Post: 10-07-2007, 01:41 PM
  3. Cruise control
    By Jimchoc in forum Passat - Archive Topics
    Last Post: 12-09-2006, 08:28 PM
  4. Cruise control for MK3 Golf GL TDI
    By Paul C in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 31-07-2006, 08:06 PM
  5. V5 Cruise Control
    By seventh-heaven in forum Beetle 2000-
    Last Post: 09-05-2006, 01:30 AM
