Thread: Unknown symbol on instrument cluster
Results 1 to 10 of 17
  1. Unknown symbol on instrument cluster
    Mar 2009
    Montenegro
    13 Post(s)
    I am a new owner of used Audi A4 Avant 1.9 tdi 2004 year. I was searching for anti theft alarm and immobilazer for my car, but I can not find any!The car does not make a horn sound when I lock him and I try to recode the adress 46 cent. conv. to add 1024 (to make a horn) to my code (06976-code of add. 46) without success! I make also a output test of same modul but there wasn't any option for alarm horn or test, only some locking and unlocking options. Then I was wandering about immobilazer and I couldn't find a sign on instrument cluster. I looked on owner's manual (which is in german- I do not understand a word!) and I recognized the symbol but on the plase of this symbol in my cluster is another symbol which I do not know what is it! I am sending a 2 pict of my cluster and I circled it.
    Please help if somebody know what is the meaning of the symbol,is it a immobilazer?
  2. Re: Unknown symbol on instrument cluster
    That's the Tyre Pressure Monitoring symbol.
  3. Re: Unknown symbol on instrument cluster
    Mar 2009
    Montenegro
    13 Post(s)
    Thanks for reply, do You know how I can check does my car have a immobilazer, because I can not see the symbol on cluster, I took these pictures during testing of instrument cluster. I have address 25 immobilazer on vag com and I enter but there is no measuring blocks and I am afraid to do the test.
  4. Re: Unknown symbol on instrument cluster
    Dec 2006
    it has an immobilizer as standard..
    if you wanted to make sure and was daring!! (IF) take the battery and chip out of the key fob and try to start it...
    I would not do it .. I would not of thought you have to recode the key after.. but i say that just in case!!
    I know when i dropped my key when running, it shattered everywhere on the floor... and it still worked when i put it back together!!
    Rick
  5. Re: Unknown symbol on instrument cluster
    Mar 2009
    Montenegro
    13 Post(s)
    I am afraid to do that thing, but I take a log of few address, can You see is there a immobilizer?
  6. Re: Unknown symbol on instrument cluster
    Southern County Softy
    20 Post(s)
    Immobilisor symbol is in the rev counter, it should light up when the ignition is first switched on.
    A4 2.5 tdi QS (mapped)
  7. Re: Unknown symbol on instrument cluster
    Mar 2009
    Montenegro
    13 Post(s)
    Yes on VW cars is like that ( I had Passat), but on Audi that symbol should be on the place where is this tire press warning lamp but as You saw it is not. I am sending a insert of audi quick reference guide concernig instrument cluster where You can see all the lamps.
  8. Wink Re: Unknown symbol on instrument cluster
    Jan 2009
    Your immob it self is built into the dash it will not show
    on the dash unless there is a fault in the immob, its a key
    shaped symbol, but this will not light after making the ignition
    live. it will only light if there is a fault,
  9. Re: Unknown symbol on instrument cluster
    Mar 2009
    Montenegro
    13 Post(s)
    Thanks for reply, I also found the same on other forum, even they told me where to check it: Address 17 measuring block 022,023,024
  10. Re: Unknown symbol on instrument cluster
    Sep 2007
    Windsor
    Quote Originally Posted by Novica View Post
    I think you have the wrong coding for the central convenience unit. See http://www.ross-tech.com/vag-com/cars/audiB6.html for more info but assuming your car is right hand drive and located in Great Britain then the coding should be 08139.
  1. Question instrument cluster
    By caravelle man in forum Chat - Anything with wheels
    Last Post: 30-01-2009, 06:31 PM
  2. Instrument cluster on the way out?
    By mrcheeezy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 08-01-2009, 12:34 PM
  3. Instrument Cluster
    By j4s0n88 in forum VCDS - General Questions
    Last Post: 03-10-2008, 06:36 PM
  4. Unknown warning symbol - help!
    By affney in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 18-09-2007, 02:58 AM
  5. A4 instrument cluster
    By alexf2828 in forum Audi A4 - Archive Topics
    Last Post: 24-06-2007, 10:20 PM
