Thread: audi tt secondary electric coolant pump
  1. audi tt secondary electric coolant pump
    Mar 2007
    hi guys can anyone help with a problem with my 2000 model year tt
    the secondary water pump has leaked coolant and caused the pump to burn out . i have replaced the pump but found on starting the engine the pump did not work on checking the fuses fuse no 16 had blown. i replaced the fuse & bingo the pump & acu compressor worked but when i switched off the engine ign key in hand the engine was still running? i had to remove fuse no 16 to stop the engine also engine cooling fans run all the time any suggestions
    Feb 2007
    Hi,these pumps can run upto 15 mins after switch off.so check to see if it cuts off,
  1. audi a4 coolant
    By lovinaudi in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-05-2007, 08:25 PM
  2. electric vacuum pump
    By gaz238 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-03-2007, 04:45 PM
  3. Secondary Car Alarm
    By andysuth in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-12-2006, 12:43 AM
  4. Audi A3 Coolant Loss
    By redsweep in forum Audi A3 - Archive Topics
    Last Post: 23-08-2006, 12:41 PM
