Thread: Alternator removal. 1.9tdi 02 plate
  1. Alternator removal. 1.9tdi 02 plate
    Mar 2009
    Heya sorry if this has been covered before but any advice would be welcome.
    I need to remove the alternator but the viscouse fan is in the way of the bottom mounting bolt.
    Is there an easy way to remove the fan or do i need to take off the front of the car?
    I tried to wedge the fan pulley but cant seem to undue the bolt at the back.
  2. Re: Alternator removal. 1.9tdi 02 plate
    Pembrokeshire
    22 Post(s)
    there should be holes in the pulley that you insert an implement through to lock the pulley opto the housing. you have to lock it, undo a little then use another hole to turn it more, and so on.you insert the tool from the rear, next to the allen bolt you are trying to undo. the holes in the pulley are barely visible.
  3. Re: Alternator removal. 1.9tdi 02 plate
    Mar 2009
    Thn for your reply
    However , i see the hole in the fan pully but when i put in a bar through the hole , there seems nothing to wedge it against , it just sort of rolls down and slides into the gap and gains no purchase when i turn the bolt.
    I must be doing it wrong and its late , thats my excuse
  4. Re: Alternator removal. 1.9tdi 02 plate
    Pembrokeshire
    22 Post(s)
    push the bar in from behind. theres a hole for it to fit through. you then have to wriggle it until it goes through the hole in the pulley.
  5. Re: Alternator removal. 1.9tdi 02 plate
    Mar 2009
    Ahh thnx m8 , i try that
  6. Re: Alternator removal. 1.9tdi 02 plate
    Jun 2008
    Glasgow
    I managed to remove the alternator in my 04 1.9TDi without removing the fan. If you loosen both bolts right off, remove the top one then pry the alternator off the top mounting with a bit of persuasion you can get it out with out removing the fan.
    Why Drive a Car when you can Pilot an Audi
    _______________________________________________
    04 Plate 1.9TDi 130 A4 Avant
    05 Plate 2.0TDi 140 A3 (My Better Half's Car)
  7. Re: Alternator removal. 1.9tdi 02 plate
    Mar 2009
    Yay , thnx guys all sorted now. it does indeed slip out nicely , if you pry it off the top mounting, the bottom bolt can be teased out
  1. compatable alternator for a6 1.9tdi 2001
    By needmorstuff in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-09-2008, 03:24 PM
  2. Please Help Alternator Removal 2.5TDI T130. T5 .
    By wacka1987 in forum The Commercial Range
    Last Post: 02-09-2008, 10:23 PM
  3. V6 tdi Alternator removal
    By scooter in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-06-2008, 12:44 PM
  4. 1.9 TDI Alternator Removal
    By tone44 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-03-2008, 03:23 PM
  5. A6 1.9TDI Alternator Pulley
    By johnnywishbone in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2007, 11:46 AM
