Thread: Oil Pressure Problems??
  1. Oil Pressure Problems??
    Mar 2009
    Hi Everyone,
    Some great information on here and some obviously knowledgeable people (hoped iv'e sucked up enough )
    maybe someone can help with the following,
    I have a 2002 Bora 1.6 petrol and the red oil pressure light started flashing, i stopped immediately and turned off the engine, the oil level indicator was at the maximum so fine, i gingerley started it up again and sounded fine, after a couple of minutes tick over and higher evs i could hear the tappets a little louder, indicating no oil getting to top of engine, the oil pressure light then started flashing again so had the car recovered without driving,
    the pick up pipe was checked and the oil replaced but still same??
    i assume it can only be the oil pump but after removing the pump its only a simple mechanical part and cant see how the pump could fail to cause low pressure?
    or is there something else to check? starting to confuse me now
    even thought the pump looks simple with hardly any parts could it fail, i spoke to the VW dealer who was suprised a pump could fail?
    any help would be much appreciated,
  2. Unhappy Re: Oil Pressure Problems??
    Jan 2011
    chesterfield england
    hi mate new to site ,looking for someone like youself with the same problems with me on going but if you want to talk over the phone i can explain what i have had done.cheers paul 07971 701654
  3. Re: Oil Pressure Problems??
    Jan 2011
    hi mate just noticed date please can you forward solution if one just about to send mine away to vw specialist. well pi**ed off
  4. Re: Oil Pressure Problems??
    Mar 2009
    i put the car back together and auctioned it, didnt want to throw money at it, if you do find a solution let me know,
  1. VW Golf Oil Pressure Light and Buzzer problems
    By mc_massingham in forum Golf MK3 - 1993 - 1999
    Last Post: 11-09-2014, 08:16 PM
  2. VW Golf Mk4 1.6 6v - Oil pressure problems/Random battery cut
    By paresh0407 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-06-2009, 10:53 PM
  3. speedo problems and oil pressure light
    By olliemonck in forum Golf MK4 - 1999 - 2004
    Last Post: 21-02-2009, 09:09 AM
  4. Oil pressure switch, problems
    By feeba281 in forum Golf MK3 - 1993 - 1999
    Last Post: 03-01-2008, 03:34 PM
  5. Problems With Abs Pressure Sensor
    By MIBBO in forum A2
    Last Post: 18-09-2007, 10:48 PM
