Thread: Is it the camshaft?
  1. Unhappy Is it the camshaft?
    Mar 2009
    Hi, first post plz be gentle lol
    I have an 03 VW Golf gt tdi pd150.
    For the last couple of weeks it had been making a funny noise on and off on harsh acceleration, sounded a bit like the exhaust was knocking or blowing.
    Then my partner took it to work last week and whatever it was that had been making the noise, went altogether.
    The noise it is now making, sounds like an air thudding noise, if that makes sense? Like when you smack your hand over the top of a pipe, only on a bigger scale. It's hard to explain lol
    Tried filming it and you can hear it on this video, but it sounds different to me
    Tried blanking off the EGR valve, as it was suggested it could be that, but thats made no difference, and after reading as much as possible on here, it is now looking like its the cam shaft
    Also, the air intake is blowing air out as well as sucking it in, if thats any help to anyone?
    Any help will be greatly appreciated.
  2. Re: Is it the camshaft?
    I had a similar fault where the air was blowing back and that was a blocked cat/exhaust.
  3. Re: Is it the camshaft?
    2005 Post(s)
    Yes, sounds like the cam. Remove the EGR valve and pull the cam cover and check the lobes of the cam but often you can only tell when the cam is removed.
  4. Re: Is it the camshaft?
    Jan 2008
    Sounds like the camshaft failure.Common fault with the 150's.Has it had regular oil changes with the correct specification oil?
    Get it looked at ASAP
  5. Re: Is it the camshaft?
    Mar 2009
    thanks to all of you for your replies.
    It was what we were thinking anyway, but it always helps to have a bit of clarification from ppl that know what they're talking about
    Will now get it sorted ASAP
  6. Re: Is it the camshaft?
    Feb 2009
    Hi there, did you get the problem fixed in the end, if so what was it and how much did it cost to fix if you dont mind me asking.
  1. Question Camshaft Sensor
    By malcolm tripp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-12-2008, 12:44 PM
  2. help 1.9 pd camshaft
    By jonathan bees in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-09-2008, 10:24 PM
  3. Camshaft Wear.
    By simba in forum Archive posts
    Last Post: 08-02-2008, 02:31 AM
  4. Camshaft Sensor (G40) - where is it?
    By Mat456 in forum Golf MK3 - 1993 - 1999
    Last Post: 25-12-2007, 11:00 AM
  5. Camshaft replacement
    By ianmars in forum Bora - 1998 - 2005
    Last Post: 11-10-2007, 03:11 PM
