Thread: Fault code identification
  1. Fault code identification
    Feb 2009
    Hi, T reg Tdi Golf 110, had a diagnostic recently and the following fault code was identified. 01282 intake manifold change over valve. Can anyone tell me what problem this could cause, have a hot start problem at moment. Also is the intake change over valve the black sensor bolted to the top of the inlet manifold and what does it do?
  2. Re: Fault code identification
    2005 Post(s)
    That is the solenoid but the flap is in the EGR valve operated by the vacumm unit on the back and it gets clogged solid and jams shut so it stops them starting, sounds like they have lost all compression when they do it. The fault code you get is normally due to a broken wire.
  1. Climatronic fault identification
    By Paul123 in forum Alhambra
    Last Post: 11-05-2011, 07:51 PM
  2. VAGCOM Fault Code 00588 - Airbag fault
    By headache56 in forum VCDS - General Questions
    Last Post: 31-01-2009, 01:05 PM
  3. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    Last Post: 16-01-2009, 06:05 PM
  4. ABS Fault, have fault code readout....
    By nemeth782 in forum Golf MK4 - 1999 - 2004
    Last Post: 30-08-2008, 12:15 PM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
