Thread: Isofix Brackets
  1. Isofix Brackets
    May 2008
    I'm considering retro fitting isofix brackets on a S Line avant, easy enough considering the captive nuts are already present. However after an enquiry to the main dealer it says that the brackets aren't available to my chassis no.
    Has anyone had experience of this or know why the brackets aren,t supported by the dealer, or is possible to order the part and fit it anyway.
    At nearly £40 a punt i want make sure it works before I order one
  2. Re: Isofix Brackets
    Midlands
    Hi, I'm not sure if you're aware, I'm also assuming you're using Britax too, that Britax have an alternative to the ISO Fix base.
    It uses the belt to fix the base to the car, basically strap it through and clamp it down. It looks exactly like the ISO fix one, but doesn't use the hooks. It works just like the ISO fix base besides the belt thing, you just click the baby seat in and out.
  3. Re: Isofix Brackets
    May 2008
    I'm not using anything yet but i was looking to go down the isofix route, however i am aware of the alternative.
    It's not really the answer i was looking for, i want to know if there was a technical reason why i cant retrofit a bracket, ie. the side impact airbags,
  4. Re: Isofix Brackets
    Angus, Scotland
    Hi there,
    I have the ISO-fix brackets, but haven't tried fitting them yet. Need to get hold of some new bolts as I got the brackets out of another A4. There should be no reason why they won't fit your car and mines. The reason the dealer has said that is they plug your VIN number into their computer and it comes up with a list of all the individual items that are on your car. Great for getting the right colour replacement rear view mirror with little or no fuss, a complete pain in the a*se when you want to buy something from them to Retro-fit!!
    I will go down on wednesday and buy the bolts then try it and report back! (Wife has the car tomorrow otherwise I would do it then )
    Paul
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  1. ISOFIX in A6
    By farmamick in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-03-2009, 03:33 PM
  2. window brackets on Bora / Golf Mk4
    By Sam the Eagle in forum Golf MK4 - 1999 - 2004
    Last Post: 18-06-2008, 04:08 PM
  3. Big Bumper Brackets
    By Dee-GTI in forum Golf MK2 - 1984 - 1992
    Last Post: 28-04-2008, 12:59 PM
  4. Plz Help:- Audi 80 Towbar bumper brackets
    By Ally80 in forum 80 - 90
    Last Post: 15-07-2007, 02:30 PM
  5. A4 ISOFIX
    By gordonjbarrie in forum Audi A4 - Archive Topics
    Last Post: 06-06-2006, 06:26 PM
