Thread: Mfd coding
  1. Mfd coding
    Mar 2009
    hi, i've had a new battery in my golf and the mfd sat nav unit now need as code to start the unit back up. I've been in vw and recieved a code but the code does work does anybody have any idea's on bypassing the coding or contact number to help me with??
  2. Re: Mfd coding
    Kinross Scotland
    If the unit you have was supplied with the car, then VW can give you the correct code from the chasis No.
    If it is a replacement unit then it has a VW code stamped on the unit and from this VW can tell you what car it was fitted to, or if it was a parts sale.
    If the origin is hookey then look on Ebay VW Navigation and there is companys who can reset/decode it for you.
    Tiguan 2.0 4Motion 140PS 01/07/2013
  3. Re: Mfd coding
    Coventry
    the radio code should be in the handbook.
    mine was - on a little credit card sized piece of card.
  1. ECU Coding
    By toniz in forum VCDS - Help Requests
    Last Post: 13-03-2011, 07:35 AM
  2. Question ECU coding
    By yuley in forum Golf MK4 - 1999 - 2004
    Last Post: 03-03-2009, 08:19 PM
  3. Question key coding again!
    By Martin Burnard in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-12-2008, 11:52 AM
  4. coding a key
    By jcb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-11-2008, 08:56 PM
  5. Help with coding in my sat nav plus
    By a6rob in forum VCDS - General Questions
    Last Post: 06-07-2008, 01:33 PM
