Thread: polo timing chain
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
  1. Re: polo timing chain
    #21
    One tooth wrong and the valves hit the pistons on the 1.9 SDI
  2. Re: polo timing chain
    #22
    7 Post(s)
    Forgot all about this thread.
    Changed the Old Dears oil last weekend.
    Very aprehensive about starting it but it was ok.
    It is a 2005 car with the 3 cylinder 1.2 engine. As above, did VW modify the tensioner by that year?
  3. Re: polo timing chain
    #23
    No, as a matter of fact we had one in on Monday,2005 mod,needless to say all the inlet valves were nackered
  4. Re: polo timing chain
    #24
    7 Post(s)
    Quote Originally Posted by kenney View Post
    Cheers Kenny,
    This is unbelievable, sods law says it's going to happen next time or the time after....
    How can such a design flaw exist in something so simple as that engine. How could VW get it SO wrong.
  5. Re: polo timing chain
    #25
    Sorry to say it,but it's only one, of many, unexplainable flaws.
  6. Re: polo timing chain
    #26
    135 Post(s)
    2026 Post(s)
    Yes like them going whappy if you clear the fault codes and needing the EGR valve re-adapting, that’s if the plug in the bottom of the EGR valve hasn’t fallen out or the cat stopped doing what it does or a lambda sensor failed or the consul bushes fallen apart and scrubbed out the tyres or the ABS fuse blown, the PS puimp stopped, the rack exploded etc etc etc…Seriously, the 9N Polo is a crap design! BUT, why is the Fabia 1 (the same platform) so much more reliable and the Ibiza 3 so much worse than even the Polo?
  7. Re: polo timing chain
    #27
    Jul 2007
    Leeds
    The valve timing could be out as could the pump timing (commencement of injection) timing. The garage you have been to have washed their hands of it so you need to go somewhere where they can pin the engine and check the cam timing and then if that is OK, set the COI. If that fails to cure it, it could be a failed dual mass flywheel.
    Thanks for the suggestions. The original garage claimed to have rechecked both the cam and COI timing, however, I think I'll take your advice and get a fresh pair of eyes on it.
    How expensive/difficult would it be to replace the flyheel if it is on the way out?
  8. Re: polo timing chain
    #28
    135 Post(s)
    2026 Post(s)
    What is your engine code and the cars year?
  9. Re: polo timing chain
    #29
    Jul 2007
    Leeds
    It's a 2001 Y regsitration. The engine code is AGP (and transmission is AEY if I've got them the right way around).
  10. Re: polo timing chain
    #30
    135 Post(s)
    2026 Post(s)
    AGP is Polo 10/99>09/01 1.9 68PS SDI engine and does not exists as a transmission code
    AEY is Polo 12/95>08/99 1.9 64PS SDI engine and does not exists as a transmission code.
    Basically, they are both engine codes…
    PM me your reg number.
  1. When to change Timing Chain on 2002 Polo 1.2 E 55 (AWY)
    By ettlz in forum Polo - Derby - Lupo - Fox
    Last Post: 25-12-2016, 09:48 PM
  2. timing chain data for fitting new chain
    By stephen gal in forum Ibiza - Cordoba
    Last Post: 26-05-2008, 03:17 AM
  3. Golf VR6, Timing chain?
    By russvr6 in forum Golf MK3 - 1993 - 1999
    Last Post: 14-10-2007, 08:24 PM
  4. V5 Timing chain
    By Bryan20 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-09-2007, 05:11 PM
  5. Timing chain tensioner
    By NIgolf in forum Passat - Archive Topics
    Last Post: 20-03-2007, 07:10 AM
