Thread: Parking sensors, front and rear - operation
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Parking sensors, front and rear - operation
    Aug 2009
    devon
    What i have noticed is the bar graph display isnt all that accurate, when its fully black i.e as far as its concerned im as close as possible to an object im trying to avoid when parking, when i stop the car and get out and have a look as to how far away it is its normally at least a foot and a half away from the car meaning i often have to move the car forward/back a bit to get it parked properly in car parks, often i just ignore them to be honest!!
  2. Re: Parking sensors, front and rear - operation
    Apr 2009
    Quote Originally Posted by HHGTTG View Post
    My new VW MK6 is going to be fitted, as a factory fit option, with parking sensors, front and rear and therefore I pose the following question.
    I can understand how the rear sensors are activated i.e. when engaging reverse gear etc. but are the front sensors active only when 1st gear is selected? If that is so then why don't they give an alarm signal when crawling slowly in traffic when the car in front is approached or has the speed of the car something to do with it?
    And what happens if you drive into a space frontwards facing a vertical wall i.e when reverse hasnt' been selected?
    Am I being ultra thick and missing something that is so obvious I cannot see the wood for the trees?
    Mine seem to work as follows:
    Both front and rear sensors activate either when you select reverse, or if you press the button. They don't operate in traffic just from 1st gear - you would need to press the button first.
    If they are already activated, pressing the button switches them off.
    Chris.
  3. Re: Parking sensors, front and rear - operation
    Nightowl4933 Guest
    I've not turned the front ones on manually, but if reverse is selected the front ones are active too. There is a different tone when closing in to obstructions at the rear and the front, and if you have the 310 the diisplay it shows a series of bars identifying how close (relatively) you are to the obstruction.
    I've not experienced the front ones working when driving forward, unless I've already selected reverse, but then I try not too close to anything in front!
    I only really wanted the reversing sensors, but I'm quite pleased I've got the front one's too - but it's quite musical when trying to reverse out around several objects!
  4. Re: Parking sensors, front and rear - operation
    South London. UK
    Quote Originally Posted by Nightowl4933 View Post
    Yes, I soon fathomed the system out when I took delivery. It was immediately obvious that the switch, forward of the gear lever was for activating the system, if it was already off and you wanted it, say, for approaching some obstacle in front.
    Selecting reverse activates both front and rear sensors and turns off when you drive away, after a few yards or can be turned off by pressing that button - all very logical really.
    2016 VW Golf MK7 Match Edition 1.4TSI 125ps 5dr in Reflex Silver.
  5. Re: Parking sensors, front and rear - operation
    Aug 2009
    Holywood, County Down
    That is a shame, as I'm sure they could get the parts if they were motivated to do so. On the other hand it offers up the possibility of using the microwave parking sensors - which employ a single long strip fixed behind the bumper i.e. there are no externally visible sensors.
    /me rapidly searches for link found a long time ago!
    Found this place, but it's not the same link I'd seen a while ago; this one looks less professional!
    Last edited by ukpm; 03-09-2009 at 04:22 PM. Reason: Corrected spelling/grammar errors
  1. front parking sensors
    By jesterjak in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 13-02-2009, 01:35 AM
  2. front parking sensors dealer fit
    By jey16 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-10-2008, 12:39 PM
  3. Rear Parking Sensors
    By Jasperse in forum Jetta MK3 - 2005 - 2013
    Last Post: 26-08-2008, 04:41 PM
  4. And this is why you shouldn't ignore your front parking sensors :(
    By james_tiger_woo in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-06-2008, 10:30 AM
  5. Another rear parking sensors
    By Rampage in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-09-2007, 09:32 PM
