Thread: golf vr6 (HELP)!!!
  1. #1
    Mar 2009
    does anyone have any idea on how i would go about getting my inlet manifold and top of my engine polished or chromed seen it done on a few vr6,s like look of it but have no clue on were to start any help appreciated cheers.......
  2. Re: golf vr6 (HELP)!!!
    May 2008
    Err, take to a company who can chrome/polish it?
    Sorry if that sounds flipant but it seems pretty obvious?!
    Google/check yellow pages to find a suitable firm close to where you live.
  3. Re: golf vr6 (HELP)!!!
    Dec 2007
    Inverness
    DIY mate!!! saves a load of dosh.
    Get some 600 grit and 1000 grit sanding paper (wet and dry, ********* for 7 or 8 quid), a sanding block, AUTOSOL and 2 rags.
    Take the manifold off, get a tub and fill it with warm soapy water (fairy liquid will do) sand it with the 600 grit till it feels nice and smooth, then go at it with the 1000 grit till its like a shiny babys rear then use rag #1 to apply autosol then rag #2 to polish it off.
    Hey presto - your very own bragging rights and a shiny inlet manifold :P
    N reg mk3 golf 1598cc
    Rolling stones anniversary trim
    dragon green
    Favourite mod - vanilla magic tree
  4. Thumbs up Re: golf vr6 (HELP)!!!
    Dec 2008
    stoke
    dnt listen to isak hunt no idea andrew has got it but id start with 80 grit sand the same way at all times once all 1 smooth ish surface then go up the grits 600_ 8000 just done myn have photos of all stages have a go once its done its mint v easy but takes adges a good week 3 hours a day expect alot of cramp !! but its worth it proberly cost me £7.90
  5. Re: golf vr6 (HELP)!!!
    Pembrokeshire
    22 Post(s)
    go and buy a cheap da sander from a discount diy place, the sort that takes the round sanding discs with the velcro backing. you should be able to pick up one for a tenner or so. this will sand up the flatter areas in a fraction of the time it will take you to do it by hand. just dont inhale the dust that comes off, as it causes all sorts of bad ailments later in life, so buy some face masks as well.
