Thread: Dripping liquid under car
Results 1 to 8 of 8
  1. Dripping liquid under car
    Feb 2009
    Hey all, new to the site and had car about 1 week.
    I was cleaning my air filter out in my 53 plate GTTDI 130 today when I thought I would start the engine and see if it sounded any better and just do a general inspection of my car underneith and engine bay. When I looked under the car about mid way down the middle of the car there is a heatshield type thing with a grove in the middle which the exhaust pipe runs through. I noticed on one side of the heatshield, the nearside I could see a see through liquid dripping from a hole in the heatshield (if thats what it is). The liquid is cool and when i dab the hole with my finger it drips out faster, ive smelt the liquid and it has no odour, im inclined to think its water.
    Is there any pipes under the heat shield that would carry water to anywhere in the car or is this just water leaking from the heatshield thats some how trapped under it? For the record its not been raining today.
    Second Problem. In my confusion to work out what the liquid was I forgot to attach the plug with wires in back up to the air filter box and when I got in the car to reverse it i switched the engine on and the dash went beep beep and the screen near the dials said "Warning", then said "Workshops emissions" followed by the yellow engine light on the dials. I reconnected the plug with wires to the airbox in the engine and now the warning thing wont disapear from my dash nor will the yellow engine light. Have I broken anything or has it done this because i didnt attach the plug, if so would a fault clear be in order, at least then if it did it again I would know its not because I didnt fit the plug to the airbox and run the engine for about 10 mins.
    Sorry its long winded but have tried to explain everything as best I can.
  2. Re: Dripping liquid under car
    The liqiud is condensation from the AC.You will have a fault logged in the ECU,it will do no harm except give a wrong diagnosis,when and if you need to have a fault code read.
  3. Re: Dripping liquid under car
    Feb 2009
    So your saying the water drip thing from heat shield is normal, and that the emissions warning light and engine light might just be the result of me not plugging the plug back into the air filter box, once its cleared things should be ok?
  4. Re: Dripping liquid under car
    Yes and yes
  5. Re: Dripping liquid under car
    Feb 2009
    Thanks buddy, thats reassuring news. only car ive had so far thats that sensitive that it shows every little niggle on the onboard computer screen. pitty i cant clear the code myself instead of having to take it to someone with vagcom every time this might happen.
  6. Re: Dripping liquid under car
    Southampton, UK.
    Quote Originally Posted by Mawders View Post
    ...pitty i cant clear the code myself instead of having to take it to someone with vagcom every time this might happen.
    You can clear the codes yourself using the shareware version of VAG-COM v409.1 (www.ross-tech.com) with an ODB-II cable (PM eshrules as he deals with this stuff, or go to the VAG-COM section on this forum). You'll also need a basic spec laptop with a USB port.
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 379,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
  7. Re: Dripping liquid under car
    If you've been using your Aircon or climatronic then the water will be from this,a common thing.Light on dash will need to be reset with Vag com or similiar software.Hope all goes ok
  8. Re: Dripping liquid under car
    Feb 2009
    Cheers for the advice peeps. I went to see a bloke who lives not far from me this morning who has vagcom. on the way to him my light and message went off. He scanned the car and the error reading was becuase I never plugged the sensor back in on the air filter box. we cleared the codes and its fine. cheers all.
  1. Leak: liquid on the garage floor after long run
    By hogwash in forum Golf MK5 - 2004 - 2009
    Last Post: 21-05-2010, 06:43 PM
  2. Polo dripping oil
    By VickyM in forum Polo - Derby - Lupo - Fox
    Last Post: 09-09-2008, 08:13 PM
  3. liquid blue
    By jcb in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-07-2008, 02:39 PM
  4. Brake fluid leak/Brown liquid on the car mat ?
    By nmh1977 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-03-2008, 03:33 PM
  5. Liquid dripping onto pedals 2000 (W) Polo
    By Dr Rock in forum Polo - Derby - Lupo - Fox
    Last Post: 04-01-2008, 08:17 PM
