Thread: One front wiper not working,
  1. One front wiper not working,
    Jul 2008
    Loch Lomond, Scotland
    Hi all
    Bit of a strange one I think, had my Altea out yesterday and the wipers were working fine with no problems or anything strange when I parked up last night at home, however this morning when I got into the car only the n/s wiper is working, the driver side didn't move and stayed in the park position in the pillar.
    Had a look and it doesn't appear stuck on anything and nothing visable underneath at the linkage, it has just stopped working.
    Have taken a quick look at fuses and as far as I can see thay are all fine, however I don't have a diagram of the fusebox to show the position of the relevant fuses.
    Where do I start looking for the problem or is it a dealer visit?
    Anybody else suffered from one wiper not working?
    Graham
  2. Re: One front wiper not working,
    Pembrokeshire
    22 Post(s)
    i would say that either the wiper arm is loose where it bolts onto the spindle or the linkage has broken. if you follow the wiper down to the bottom of the arm, there will be a plastic cover over the spindle. pop this off and put the wipers on. if you can see the spindle moving, tighten the bolt. if not you need to look at the linkages below.
  3. Re: One front wiper not working,
    Jul 2008
    Hi zollaf
    Thanks for your reply, I have taken a look at the spindle and the linkage and they are fine, the motor doesn't appear to be working so I don't know if it has packed in?
    After exhausting my skills I have just taken it to a local garage who will no doubt charge me a fortune
  4. Re: One front wiper not working,
    Sep 2007
    Windsor
    Normally it is one motor that operates both wipers. Are you able to move the o/s wiper by hand?
  5. Re: One front wiper not working,
    Jul 2008
    Well I have finally got the problem sorted.
    The Altea has 2 wiper motors and at first it was thought that the offside motor had gone so a new one was ordered and fitted but didn't solve the problem.
    It is now come to light, via Seat, that there are problems with some Altea's with some of the wiring behind the dash rubbing through and breaking the power cable, this was the case with my Altea and what a job that turned out to be.
    Anyway thanks for your replies and help
    Graham
  1. Rear Wiper on Avant not working...
    By ross_Darroch in forum 80 - 90
    Last Post: 10-04-2011, 12:38 PM
  2. Rear wiper motor not working
    By redijedidedi in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 17-02-2009, 07:09 PM
  3. wiper not working
    By saintor in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-02-2009, 10:22 PM
  4. rear wiper not working
    By colly27 in forum Golf MK4 - 1999 - 2004
    Last Post: 16-01-2008, 10:53 AM
  5. intermittent wiper not working
    By Jamie b in forum Golf MK4 - 1999 - 2004
    Last Post: 23-11-2007, 09:15 PM
