Thread: Remove RCD 300 Radio in Golf Plus 2006
Results 1 to 8 of 8
Hybrid View
  1. Remove RCD 300 Radio in Golf Plus 2006
    Mar 2009
    Hello,
    Can anybody help with this?
    I need to remove the RDC 300 Radio in my Golf Plus to fit some extra bits.
    The question really is: what trim part needs to be removed first and where are the clips?
    See pickture.
    Many thanks,
  2. Re: Remove RCD 300 Radio in Golf Plus 2006
    Dec 2006
    Wiltshire
    This is not a 5 minute job on a Golf PLUS !!!
    The entire trim need to come off, have a look at the how to's on here - I'm sure some poor sod has already suffered this.
    From memory you have to take the dash-top trim out and work your way down. And then the vents fall apart and it takes 3 hours to put them back together again. Then you can put it all back together again.
    A6 (2007)TDi SE Avant
    Gone but not forgotten - A4 2.5TDi Avant, Imola Yellow S3 , Golf VR6 Highline
  3. Re: Remove RCD 300 Radio in Golf Plus 2006
    Mar 2009
    Hello,
    Thanks for the tip, however I have found the solution from a German website.
    See: http://www.keipke.de/wiki/display/HO...RCD300+mit+MP3
    I followed this process and it took me about 30 minutes to remove and reinstall the radio.
    Hope this can help other people.
    Regards
  4. Re: Remove RCD 300 Radio in Golf Plus 2006
    Mar 2010
    bristol
    Further help on my Golf Plus RCD radio removal
    I cannot read the German text but managed to remove two screws behind covers for airbag warning and air vent slot.
    Now I find that the panel surrounding the radio and the 4 vents is very tight.
    Does it just pull off, or are there other screws ?
    Please advise before I force and break it.
  5. Re: Remove RCD 300 Radio in Golf Plus 2006
    Mar 2009
    There are no other screws exept those behind the cardholder that looks like a small vent and the passenger airbag warning panel.
    Be carefull when you remove the panel as there are 4 or 6 clips that hold the panel in place. If I remember well, there are 2 clips on each side and 2 at the bottom. Proceed slowly and with care. I did this a few times and it went OK.
    Good luck,
    Roland
  6. Re: Remove RCD 300 Radio in Golf Plus 2006
    Sep 2009
    london
    Hi - I know that is a old post that you have out there regarding the Golf Plus radio removal - But I was wondering if you can help, I have removed the 2 screws under the hazard lights but I still cannot take of the panel around the car radio. Is there any other screw, were are they. NOTE my dash is the same as what is in your picture, any help would be much appreciated.
  1. How To Remove Mk5 Radio
    By daniel408 in forum Golf MK5 - 2004 - 2009
    Last Post: 14-05-2008, 06:51 PM
  2. remove sharan radio
    By Hywel in forum Touran - Sharan - Caravelle
    Last Post: 10-05-2008, 02:24 PM
  3. How to remove the audio (radio/CD) kit?
    By rjs993 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-01-2008, 04:41 PM
  4. MK5 Golf 2006 2.0 TDI
    By infusion in forum Golf MK5 - 2004 - 2009
    Last Post: 23-10-2007, 11:34 AM
  5. Replies: 1
    Last Post: 22-10-2007, 10:13 PM
