Thread: Is my MAF faulty? Symptoms
  1. Is my MAF faulty? Symptoms
    Im just wondering if anyone could possibly point me in the right direction.
    Symptoms are engine revs pulse/surge up and down randomly at idle (like someone is pumping the accelerator) normally when first started, fuel consumption has gone up. The guy at the garage said it may be the MAF sensor but didn't want to take his word for it as he seemed a bit shifty.
    I have a fault code from the shareware version of vag-com I will try to post when I get home.... Anyone?....
  2. Re: Is my MAF faulty? Symptoms
    Fault code as follows:
    VAG-COM Version: Release 409.1-S
    Control Module Part Number: 06A 906 033 J
    Component and/or Version: SIMOS33 1,6l 2V 00HS3488
    Software Coding: 00011
    Work Shop Code: WSC 06435
    Additional Info: WAUZZZ8LZ1A024232 AUZ5Z0Y8054135
    3 Faults Found:
    17549 - Load Calculation Cross Check: Implausible Value
    P1141 - 35-10 - - - Intermittent
    16556 - Shareware Version. To Decode all DTCs
    P0172 - 35-10 - Please Register/Activate - Intermittent
  3. Re: Is my MAF faulty? Symptoms
    134 Post(s)
    2007 Post(s)
    Your car is a 2001 A3 with an AVU 101PS engine and manual box for those that would like to know.
    16556 Fuel metering system too rich” which is there twice for some reason but it is the free shareware version so no complaints there.
    I suggest you fit a new genuine Audi dealer supplied Air Mass Meter, DO NOT buy one anywhere else, not matter how good it seems or how cheap it is.
  4. Re: Is my MAF faulty? Symptoms
    Thankyou for taking the time to reply!
    I've read on many sites that you can clean the MAF sensor, should I try this or just cut my losses and buy a new one?
  5. Re: Is my MAF faulty? Symptoms
    134 Post(s)
    2007 Post(s)
    Cleaning the AMM is very hit and miss, the best way is to buy a new one. When we have issues like this in the workshop the cheapest way to diagnose an AMM is to fit a new one and if that fails to cure the problem, it is no big deal as they don’t cost very much, less than an hours labour at Audi.
  1. Failing Maf Symptoms
    By PETER G in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-02-2009, 11:52 AM
  2. what symptoms would i get from faulty coolant sensor
    By vwpassat1.8juic in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-11-2008, 08:29 PM
  3. Faulty Earth symptoms and solutions
    By sumomus_01 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-07-2008, 06:35 PM
  4. Symptoms of faulty MAF?
    By FastMan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-01-2008, 04:47 PM
  5. Please help , look at these symptoms.
    By nutter1980 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-12-2007, 02:00 AM
