Thread: Passat B5 Rear Speakers
Results 1 to 10 of 11
  1. Question Passat B5 Rear Speakers
    DAVE NIC Guest
    Hi all.
    This is my first thread so here goes.
    My 2002 130 TDi Passat Sport Estate has the VW factory fitted in-dash 6 cd changer/radio cassette unit fitted. Just discovered there is no sound coming from the rear near side speakers when I put fader full to rear & balance full to near side with volume up ie. neither the tweeter or main speaker works. All the other speakers are fine though when I adjust fader/balance back to centre.
    Do you think this could be a loose wiring connection in the door or a blown speaker problem - seems strange no sound from both so suspect a possible loose connector problem - hopefully not a head unit problem.
    Any advice how to fix would be very much appreciated. Thanks.
  2. Re: Passat B5 Rear Speakers
    Jun 2006
    UK, Mids
    The connection near the door hinge can fail. You may be able to unplug and touch wires from a 9v batter onto the speaker wires and see if you hear the speaker pop when you connect and disconnect. At least this will show the speaker and wire to the door inner jamb is OK. Sorry I don't know which wire is which, some will be for windows and locking I presume.
    Audi A8 - 2015 - 3.0TDI
  3. Re: Passat B5 Rear Speakers
    Norfolk
    Should be red/green and brown/green wires going from B-Post to door. There is a connector there somewhere. That is likely to be the problem.
  4. Re: Passat B5 Rear Speakers
    DAVE NIC Guest
    Quote Originally Posted by snapdragon View Post
    Hi.
    Thanks very much for your advice. I will have a look this weekend at the connection at the door hinge.
    Regards.
  5. Re: Passat B5 Rear Speakers
    DAVE NIC Guest
    Quote Originally Posted by martin1810 View Post
    Hi.
    Thanks very much for the advice on the wiring colour coding. Hopingto check it out this weekend. Hopefully if I can fix should make a big difference to the sound quality in the back.
    Regards.
  6. Re: Passat B5 Rear Speakers
    DAVE NIC Guest
    Hi.checked the connector but all seems to be ok there - no broken wires or corrosion I could see. Disconnected & reconnected it but no joy. Didn't manage to test the speakers so I am at a bit of a loss as to what to do now. I did try to start taking the door card off to try & get to the speakers but although I got it partly off it seemed reluctant to come off fully & I didn't want to break it so stopped. Possible clips inside the interior door handle hold it to the inside metal door frame ? Any further ideas anyone ? Thanks.
  7. Re: Passat B5 Rear Speakers
    Norfolk
    I would try pulling off the door connector and connecting to a spare speaker. If that don't work you know the fault is either the player or the wires from the player. Saves taking door apart.
  8. Re: Passat B5 Rear Speakers
    DAVE NIC Guest
    Hi. Thanks again for the additional advice. I will try & get hold off an old speaker from a scrapyard & give it a go as you suggest - makes a lot of sense instead of pulling the door to bits at this stage.
    Regards.
  9. Re: Passat B5 Rear Speakers
    Jun 2006
    UK, Mids
    You could get a new speaker from Maplins if there is one near you..
    http://www.maplin.co.uk/Module.aspx?ModuleNo=98088
  10. Re: Passat B5 Rear Speakers
    DAVE NIC Guest
    Hi.
    Thanks again for your help & the Maplin link. Should do the job nicely & there is a branch near to me.
    Cheers.
  1. Help, Rear Speakers
    By Audiruss in forum Audi A3 - Archive Topics
    Last Post: 14-02-2009, 05:09 PM
  2. Rear door speakers Passat 1.9TDi S
    By skyhawk in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-02-2009, 05:22 PM
  3. Rear Speakers
    By Stuart_B in forum Golf MK4 - 1999 - 2004
    Last Post: 09-11-2008, 02:13 PM
  4. passat 98 rear speakers
    By gmm in forum Passat - Archive Topics
    Last Post: 21-02-2007, 07:01 PM
  5. Rear Speakers Nerw Model Passat
    By mccabe in forum Passat - Archive Topics
    Last Post: 13-02-2007, 10:51 AM
