Thread: revs dropping
  1. revs dropping
    hi folks
    i have only recently started reusing the wifes 98 passat 1.8 20v turbo
    the battery had to be recharged as it went flat and ever since then when you are driving as you approach a junction or traffic lights and dip the clutch the revs seem to drop as if it is going to stall then returns to normal
    it idles fine and starts fine and is running fine just seems to do this one strange thing
    any help most welcome
  2. Re: revs dropping
    Jan 2009
    towcester northants
    needs the throttle resetting with diag tool
  3. Re: revs dropping
    can only vag do this or can an independent garage sort it?
    thanks
  4. Re: revs dropping
    Jan 2009
    towcester northants
    any garage or independant that has a diag tool capable of task
    ie vag1552/vag com/snap on modus/ethos
    do the phone round
    whrer abouts are you in the country?
  5. Re: revs dropping
    romford essex
  6. Re: revs dropping
    Jan 2009
    towcester northants
    if you look on the dealers section you should find a specialist near you who would adapt throttle
  1. keeps dropping out of 5th gear after running for a while
    By bigbennybenstyl in forum Touran - Sharan - Caravelle
    Last Post: 15-04-2008, 10:31 PM
  2. revs dropping when dipping the clutch
    By uplink1001 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-12-2007, 11:05 AM
  3. mk3 dropping in revs
    By aharrod in forum Golf MK3 - 1993 - 1999
    Last Post: 09-11-2007, 12:07 PM
  4. Clutch pedal dropping
    By VOLKSWAGEN007 in forum Golf MK4 - 1999 - 2004
    Last Post: 06-11-2007, 11:18 PM
  5. Kangaroo-ing at low revs and Revs staying high on Gearchange.
    By Dancake in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2007, 05:50 PM
