Thread: Rear Door Deadlocked Shut
  1. Rear Door Deadlocked Shut
    Mar 2009
    My rear door on my golf is deadlocked shut.
    Wont open with the fob or drivers switch.
    To add to the problem I think the module is draining my battery.
    Anyone any idea how to open it, as removing the door panel from the inside will probably result in damage and a bad temper!
  2. Re: Rear Door Deadlocked Shut
    Near Blackpool
    48 Post(s)
    Quote Originally Posted by frustrated9 View Post
    The only real way that i know of is to hack the door panel off. I have been told by my garage they do atleast one a week where the lock module has failed shut. I would suggest you source a new door card and get dismantling.
  3. Re: Rear Door Deadlocked Shut
    Mar 2009
    My gosh, finally got the door open.
    I would not wish this task on anyone.
    Had to smash the hell out of the lock from the inside whilst squashed up like a sardine.
    Still got to remove the whole mechanism but need a tiny spline key to remove the rear outer door handle.
    What a bad design.
  1. Rear drivers door locked shut.
    By gbdxo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-02-2009, 03:44 PM
  2. Rear passenger door jammed shut
    By oa5599 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-12-2008, 09:30 PM
  3. Please Help Mk 4 rear door stuck shut
    By giggsy07 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-12-2008, 12:40 PM
  4. Rear Offside Passenger Door Locked Shut
    By Tony1010 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-10-2008, 12:34 PM
  5. ABS light on - deadlocked door - help
    By limawhiskey in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-08-2007, 10:38 AM
