Thread: Battery drain
  1. Battery drain
    Feb 2009
    Hi all,
    Wondering if anyone could steer me in the right direction.
    I have a 1986 MK2 Golf GTI 8V, If i leave the car for two days without starting the battery will drain so i can not start it. When trying to start there is not enough power to turn it over. I can jump lead it and it starts straight away, i leave it to idle for a few minites and switch off and try again and it starts no problems. it has a new battery, positive & negitive cables.
    Can anyone give possible solutions.
    Many thanks
    Dave
  2. Re: Battery drain
    Jan 2009
    towcester northants
    connect ammeter to cars battery and pull fuse 1 by 1 to find circuit causing problem
  3. Re: Battery drain
    Feb 2009
    Thanks for the advice... I did this and it seems to be the electronic fuel pump circuit.
    Wondering if anyone has had the same problems within this area and is there anything i need to look out for?
    Many thanks
    Dave
  4. Re: Battery drain
    Jan 2009
    towcester northants
    check wiring under rear seat
    also check the fuse box/relay plate for water ingress
    the coolant level sensor in the header tank sometimes leak and coolant travels down wiring into the fuse box about the area of the fuel pump relay and corrodes the relay plate
    if this has happened then it is cleanable and you will have to mod the coolant level sensor wiring and replace sensor
  5. Re: Battery drain
    Feb 2009
    Cheers for the latest info... I have now sorted it. I followed the rear loom and the previous owner had installed a fuel cut off and using a relay that had shorted. Removed it and all ok
  1. a4 battery drain
    By hail in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-02-2009, 11:17 PM
  2. a3 battery drain
    By scotty66 in forum Chat - Anything with wheels
    Last Post: 21-10-2008, 06:59 PM
  3. battery drain
    By jasey1007 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-02-2008, 08:29 PM
  4. Battery Drain
    By Philler Cap in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-02-2008, 07:17 PM
  5. Battery drain
    By nickasaki in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-10-2006, 01:51 PM
