Thread: 2l 2e engine running problems
  1. 2l 2e engine running problems
    Dec 2007
    Hi i have an early mk3 gti with a 2e engine, a while ago it started having issues with stalling (the age old problem of the idle going well below where idles should go lol) i gave the throttle body a good ol scrub and then noticed that the oil breather pipes (infact just the small section of pipe leading off of the oil breather) had a gaping great hole in it and was also closing in on its self choking the engine.
    i replaced that pipe and cleaned out the breather pod and it stopped stalling and was running alot better
    but for some reason now the fuel economy has gone right down the pan its gone from 30mpg (not really driving too cautiously) to around 12mpg driving pretty carefully
    any ideas?
  2. Re: 2l 2e engine running problems
    Jan 2009
    towcester northants
    get a diag test done
    poss temp sender
    if you set up co and idle you must disconnect the temp sender and rev car to 3000 rpm and back to idle to set ecu into base setting
  3. Re: 2l 2e engine running problems
    Dec 2007
    "if you set up co and idle" sorry i dont quite follow you there mate
    i will get a vagcom reader and have a looksy
    ps is there a specific vagcom lead i need i just looked through ebay and there seems to be a fair few different leads
    cheers
  4. Re: 2l 2e engine running problems
    Jan 2009
    towcester northants
    2e engines were digifant injection
    you could set up the idle using idle screw in throttle body and the co/mixture using a 5mm allen key in air flow meter 850rpm 1.2%co
  5. Re: 2l 2e engine running problems
    134 Post(s)
    2010 Post(s)
    You can’t set the idle/Co without putting the ECU into Basic Settings mode and that can’t be done with VAG-COM shareware, only a registered copy.
  6. Re: 2l 2e engine running problems
    Dec 2007
    erm ok. so wat do i need....
  7. Re: 2l 2e engine running problems
    134 Post(s)
    2010 Post(s)
    A cable for VAG-COM and you will also need the 16 pin OBD II to 2x2 pin adapter cable. Then download the VAG-COM 409 software from Ross Tech and then pay them $99 to register the software which will allow you to perform Basic Settings.
  1. Running problems
    By georgedart in forum Golf MK3 - 1993 - 1999
    Last Post: 09-03-2009, 10:12 AM
  2. TDI 1Z running problems
    By jomo in forum Chat - Anything with wheels
    Last Post: 20-02-2008, 12:23 PM
  3. 99 Cabriolet engine running problems...
    By MartinAnderson in forum Golf MK4 - 1999 - 2004
    Last Post: 19-09-2007, 02:07 PM
  4. running problems
    By bobby b in forum Audi A4 - Archive Topics
    Last Post: 05-01-2007, 09:34 PM
  5. RUNNING PROBLEMS
    By josianlib in forum Archive posts
    Last Post: 13-01-2005, 06:00 PM
