Thread: Reverse Light Switch
Results 1 to 9 of 9
  1. Reverse Light Switch
    Scotland
    Can anyone inform me of the location of the reverse light switch on a Mk2 VW Sharan, lights are no longer working.
    Ian
    (and yes have checked the bulbs )
  2. Re: Reverse Light Switch
    Jan 2009
    towcester northants
    manual or auto?
  3. Re: Reverse Light Switch
    Scotland
    It's a manual 6 speed
  4. Re: Reverse Light Switch
    Jan 2009
    towcester northants
    reverse light switch isat the front top of gearbox
    a bit of a pig to get to on sharan
    might be easier to take battery out and battery tray to gain access also you can check wiring below battery as this does break
  5. Re: Reverse Light Switch
    Scotland
    Many thanks, sounds like a job when I'm off for a week at the end of the month.....
  6. Re: Reverse Light Switch
    Just be aware that the 4 larger bolts that appear to hold the battery tray in place also provide support for the engine/gearbox. When you undo these the engine will drop a few inches and you will need to jack/lift the engine back up to bolt the tray back in place.
    And yes the switch is a pain to get to even when youve done this.
    Not impossible but the engine dropping is a bit of a shock when it happens.
  7. Re: Reverse Light Switch
    Scotland
    Mmmmm......... I think maybe I'll just leave it alone, seems alot of effort for something I've lived with for a couple of years
  8. Re: Reverse Light Switch
    Feb 2009
    No!. you can do it from underneath after removing the sump/engine shield, i had this on a 6sp galaxy, after wanting one in a hurry they were only avaliable from ford overnight (Part no. 1439597) VW and audi were all backorder.
    Mine had let damp into and corroded the terminals.
  9. Re: Reverse Light Switch
    Scotland
    Excellent, thanks for the info! Will check it out at the end of the month
    By Mackenzie_Mark in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-01-2011, 07:11 PM
  2. Reverse light switch
    By producedapples in forum Golf MK4 - 1999 - 2004
    Last Post: 10-04-2009, 03:09 PM
  3. reverse light switch
    By andytdi in forum Chat - Anything with wheels
    Last Post: 17-01-2009, 10:30 PM
  4. Question reverse light switch
    By anz in forum Audi A3 - Archive Topics
    Last Post: 25-11-2008, 12:12 AM
  5. reverse light switch
    By ashab02 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-12-2007, 10:14 PM
