Thread: 98A4 1.8T MAF? Need Help
  1. 98A4 1.8T MAF? Need Help
    Feb 2009
    I purchased a used 98 Audi A4 1.8LT quattro- I've already replaced the MAF, fuel filter, ignition coils, cleaned tran filter/pan, timing ok
    - STILL HAVE NO ACCELERATION! Maybe only 1/2 the power. Running rich according to my vagcom but no faults showing. I need to find out the correct Mass Air Flow readings from zero to red line on a factory standard engine.
    Also, any other ideas about what could be causing the problem??? I'm so very frustrated with the car Thanks for the help.
  2. Re: 98A4 1.8T MAF? Need Help
    Feb 2009
    Try disconnecting the Mass Air Flow meter and see if it runs any better. If so, there could be an air leak around the piping to/from the intercooler.
