Thread: Passat tdi 110bhp fault code 00519
  1. Passat tdi 110bhp fault code 00519
    Mar 2009
    hi,
    ive had this problem for a while now which of late ive decided to try and sort out . basically put your foot down and the car goes into limp home mode.
    i bought a code reader and the code 00519 came up so i bought a new map sensor and fitted it into the pipe that runs across the rear of the engine, erased codes and drove it again , same code came up again. so today i fitted a new maf sensor and it happened again.
    im sort of beginning to give up on this , so would appreciate it if anybody knows what i could try next.
    thanks pete
  2. Re: Passat tdi 110bhp fault code 00519
    Intake manifold pressure sender -G71
    implausible signal
    Charge pressure control solenoid valve (N75) defective Check N75
    Control unit defective
    Hose connections interchanged, not connected
    Reduced output
    Increased emission figures
    Short to positive
    Short to earth
  3. Re: Passat tdi 110bhp fault code 00519
    Norfolk
    That's the danger of following the scan report. Just because a sensor signal is odd it doesn't mean the sensor is faulty. I would pull the vacuum pipe off the turbo acuator and try sucking or blowing. If you can do either you have a vacuum leak and need to change the pipes. I always start here regardless because it costs peanuts and often works.
  4. Re: Passat tdi 110bhp fault code 00519
    Mar 2010
    bolton,england
    with engine running pull the vac hose off the wastgate on top of the turbo,check its pulling air,just stick ur finger on the end,if it isnt u hav a vac leak and need to replace hoses,if it sticks to your finger then look at the rod imbetween the wastgate and turbo,wen u pull off the vac line the rod should drop about 20mm,mine was seized and only moved 4mm so spray loads of wd40 on it then get some long nosed pliers and push it down,you will feel it crack as it frees up,keep puting the hose on and off watch it,it will go up and down,now take your car on the motorway,in 3rd gear get the revs up to 4.5 and clear ur turbo out,chances are it will have **** in it. hope this is of use mine had every symptom you had and is now fine.
  5. Re: Passat tdi 110bhp fault code 00519
    Pembrokeshire
    22 Post(s)
    Quote Originally Posted by martin1810 View Post
    thats also the problem with a code reader only that wont read live data. if it did you could look at the map sensor readings and see if it was actually faulty or not.
  6. Re: Passat tdi 110bhp fault code 00519
    Mar 2009
    hi , just to let u know that my dad now has the car but we did fix the problem, it was the MAP sensor, so we got that de soldered from the ecu and fitted a aftermarket external one.
    cheers for ur help tho .
    pete
  1. 01222 fault code on Passat
    By Mark Redman in forum VCDS - Help Requests
    Last Post: 04-03-2011, 01:03 AM
  2. Passat Fault Code
    By Colestation in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 06-12-2008, 06:17 PM
  3. Passat error code 4621? Throttle Valve Control Fault?
    By red_avant in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-11-2008, 11:52 PM
  4. Passat fault code (17964)
    By gordy79 in forum VCDS - General Questions
    Last Post: 05-05-2008, 11:19 PM
  5. passat 2.0se 2001 fault code
    By mendit in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2008, 10:55 PM
